Update auf 5.7.2
Hallo Community,
Shopware lässt sich nicht öffnen.
HTTP ERROR 500
Fatal error: Uncaught Symfony\Component\DependencyInjection\Exception\ServiceNotFoundException: The „wbm_tag_manager.variables“
service or alias has been removed or inlined when the container was compiled. You should either make it public, or stop using
the container directly and use dependency injection instead.
in /homepages/4/d690300519/htdocs/shopware/vendor/symfony/dependency-injection/Container.php:275 Stack trace:
#0 /homepages/4/d690300519/htdocs/shopware/vendor/symfony/dependency-injection/Container.php(231):
Symfony\Component\DependencyInjection\Container->make(‚wbm_tag_manager…‘, 1)
#1 /homepages/4/d690300519/htdocs/shopware/engine/Shopware/Components/DependencyInjection/Container.php(210):
Symfony\Component\DependencyInjection\Container->get(‚wbm_tag_manager…‘, 1)
#2 /homepages/4/d690300519/htdocs/shopware/engine/Shopware/Components/DependencyInjection/Container.php(134):
Shopware\Components\DependencyInjection\Container->doLoad(‚wbm_tag_manager…‘, ‚wbm_tag_manager…‘, 1)
#3 /homepages/4/d690300519/htdo in /homepages/4/d690300519/htdocs/shopware/vendor/symfony/dependency-injection/Container.php on line 275
Kann mir Jemand weiter helfen?
Dankeschön
Edu
Deaktiviere mal das Plugin „Tag Manager“ über die Datenbank.
Vielen Dank! Ich werde es probieren.
Ansonsten einfach nochmal melden. :slightly_smiling_face:
Es hat alles geklappt!
Vielen Dank
