Update 3.5.7 auf 4.0.4 Fehlermeldung
Hallo Leute habe folgende Fehlermeldung, kann mir bitte jemand helfen. Danke Ihr Server muss die folgenden Systemvoraussetzungen erfüllen, damit Shopware lauffähig ist Slim Application Error The application could not run because of the following error: Details Code: 8 Message: Undefined offset: 1 File: /var/www/htdocs/ks4312/html/update/libs/Shopware/Components/Check/System.php Line: 324 #0 /var/www/htdocs/ks4312/html/update/libs/Shopware/Components/Check/System.php(324): Slim::handleErrors(8, ‚Undefined offse…‘, ‚/var/www/htdocs…‘, 324, Array) #1 /var/www/htdocs/ks4312/html/update/libs/Shopware/Components/Check/System.php(83): Shopware_Components_Check_System::decodeSize(false) #2 /var/www/htdocs/ks4312/html/update/libs/Shopware/Components/Check/System.php(31): Shopware_Components_Check_System->compare(‚disk_free_space‘, false, ‚5 GB‘) #3 /var/www/htdocs/ks4312/html/update/libs/Shopware/Components/Check/System.php(98): Shopware_Components_Check_System->getList() #4 /var/www/htdocs/ks4312/html/update/templates/system.php(40): Shopware_Components_Check_System->getIterator() #5 /var/www/htdocs/ks4312/html/update/libs/Slim/View.php(195): require(’/var/www/htdocs…’) #6 /var/www/htdocs/ks4312/html/update/libs/Slim/View.php(179): Slim_View->render(‚system.php‘) #7 /var/www/htdocs/ks4312/html/update/libs/Slim/View.php(167): Slim_View->fetch(‚system.php‘) #8 /var/www/htdocs/ks4312/html/update/libs/Slim/Slim.php(618): Slim_View->display(‚system.php‘) #9 /var/www/htdocs/ks4312/html/update/libs/Shopware/Update.php(282): Slim->render(‚system.php‘, Array) #10 [internal function]: {closure}() #11 /var/www/htdocs/ks4312/html/update/libs/Slim/Router.php(178): call_user_func_array(Object(Closure), Array) #12 /var/www/htdocs/ks4312/html/update/libs/Slim/Slim.php(1149): Slim_Router->dispatch(Object(Slim_Route)) #13 /var/www/htdocs/ks4312/html/update/libs/Slim/Middleware/Flash.php(84): Slim->call() #14 /var/www/htdocs/ks4312/html/update/libs/Slim/Middleware/MethodOverride.php(91): Slim_Middleware_Flash->call() #15 /var/www/htdocs/ks4312/html/update/libs/Slim/Middleware/PrettyExceptions.php(65): Slim_Middleware_MethodOverride->call() #16 /var/www/htdocs/ks4312/html/update/libs/Slim/Slim.php(1100): Slim_Middleware_PrettyExceptions->call() #17 /var/www/htdocs/ks4312/html/update/index.php(53): Slim->run() #18 {main}
Hallo Leute, hat niemand das gleiche Problem? Hat jemand schon von 3.5.7 auf 4.0.4 upgedatet? Oder liegt´s an was anderem? Danke
Hi, es scheint so, als ob das Script den freien Speicherplatz auf deinem Server nicht richtig erkennt. Manche Server-Konfigurationen unterdrücken diesen Wert. Wenn dem so ist kannst du, sofern die Systemvoraussetzungen alle gegeben sind, die Überprüfung löschen. Somit wird der freie Speicherplatz auf dem Server nicht abgefragt: Im Update Script unter /templates/system.php die Zeilen 40-62 auskommentieren.
[quote=“Mario Bölt”]Hi, es scheint so, als ob das Script den freien Speicherplatz auf deinem Server nicht richtig erkennt. Manche Server-Konfigurationen unterdrücken diesen Wert. Wenn dem so ist kannst du, sofern die Systemvoraussetzungen alle gegeben sind, die Überprüfung löschen. Somit wird der freie Speicherplatz auf dem Server nicht abgefragt: Im Update Script unter /templates/system.php die Zeilen 40-62 auskommentieren.[/quote] Habe es probiert und es kommt erneut einen neue Fehlermeldung. Das mit dem Speicherplatz kann gut möglich sein, weil wenn ich es im Backend 3.5.7/Einstellungen/Systeminfo anschaue kommt Speicherplatz vorhanden 0. Aber als ich die 3.5.x installiert habe, ist allerdings wegen dem Speicherplatz keine Fehlermeldung gekommen, es wurde nur rot markiert. Hier die neue Fehlermeldung: Slim Application Error The application could not run because of the following error: Details Code: 2 Message: file_get_contents(http://store.shopware.de/storeApi) [function.file-get-contents]: failed to open stream: HTTP request failed! File: /var/www/htdocs/ks4312/html/update/libs/Shopware/Update.php Line: 2060 Trace #0 [internal function]: Slim->handleErrors(2, ‘file_get_conten…’, ‘/var/www/htdocs…’, 2060, Array) #1 /var/www/htdocs/ks4312/html/update/libs/Shopware/Update.php(2060): file_get_contents(‘http://store.sh…’, false, Resource id #12) #2 /var/www/htdocs/ks4312/html/update/libs/Shopware/Update.php(1825): Shopware_Update->doStoreApiRequest(‘product’, Array) #3 /var/www/htdocs/ks4312/html/update/libs/Shopware/Update.php(280): Shopware_Update->getCustomList() #4 [internal function]: {closure}() #5 /var/www/htdocs/ks4312/html/update/libs/Slim/Router.php(178): call_user_func_array(Object(Closure), Array) #6 /var/www/htdocs/ks4312/html/update/libs/Slim/Slim.php(1149): Slim_Router->dispatch(Object(Slim_Route)) #7 /var/www/htdocs/ks4312/html/update/libs/Slim/Middleware/Flash.php(84): Slim->call() #8 /var/www/htdocs/ks4312/html/update/libs/Slim/Middleware/MethodOverride.php(91): Slim_Middleware_Flash->call() #9 /var/www/htdocs/ks4312/html/update/libs/Slim/Middleware/PrettyExceptions.php(65): Slim_Middleware_MethodOverride->call() #10 /var/www/htdocs/ks4312/html/update/libs/Slim/Slim.php(1100): Slim_Middleware_PrettyExceptions->call() #11 /var/www/htdocs/ks4312/html/update/index.php(53): Slim->run() #12 {main}
Hallo Mario, Auskommentieren hat nicht funktioniert. Habe dann die Zeilen 39-64 in der templates/system.php gelöscht. Da ich nicht sicher war ob alle Systemanforderungen erfüllt sind, habe ich die check 4.0.4 geladen und die Systemanforderungen getestet. http://files.shopware.de/download.php?package=check_4 Danke Mario
