Hallo zusammen, wollte mir gerade Shopware 4.1.2 installieren, bekomme aber nach dem ersten Schritt folgende Fehlermeldung Slim Application Error The application could not run because of the following error: Details Type: ErrorException Code: 8 Message: Undefined offset: 1 File: /var/www/web116/html/install/assets/php/Shopware\_Install\_Requirements.php Line: 396 Trace #0 /var/www/web116/html/install/assets/php/Shopware\_Install\_Requirements.php(396): Slim\Slim::handleErrors(8, 'Undefined offse...', '/var/www/web116...', 396, Array) #1 /var/www/web116/html/install/assets/php/Shopware\_Install\_Requirements.php(128): Shopware\_Install\_Requirements::decodeSize(false) #2 /var/www/web116/html/install/assets/php/Shopware\_Install\_Requirements.php(60): Shopware\_Install\_Requirements-\>compare('disk\_free\_space', false, '5 GB') #3 /var/www/web116/html/install/assets/php/Shopware\_Install\_Requirements.php(78): Shopware\_Install\_Requirements-\>checkAll() #4 /var/www/web116/html/install/assets/php/Shopware\_Install\_Requirements.php(434): Shopware\_Install\_Requirements-\>getList() #5 /var/www/web116/html/install/assets/php/Index.php(102): Shopware\_Install\_Requirements-\>toArray() #6 [internal function]: {closure}() #7 /var/www/web116/html/engine/Library/Slim/Router.php(172): call\_user\_func\_array(Object(Closure), Array) #8 /var/www/web116/html/engine/Library/Slim/Slim.php(1225): Slim\Router-\>dispatch(Object(Slim\Route)) #9 /var/www/web116/html/engine/Library/Slim/Middleware/Flash.php(86): Slim\Slim-\>call() #10 /var/www/web116/html/engine/Library/Slim/Middleware/MethodOverride.php(94): Slim\Middleware\Flash-\>call() #11 /var/www/web116/html/engine/Library/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride-\>call() #12 /var/www/web116/html/engine/Library/Slim/Slim.php(1176): Slim\Middleware\PrettyExceptions-\>call() #13 /var/www/web116/html/install/assets/php/Index.php(302): Slim\Slim-\>run() #14 /var/www/web116/html/install/index.php(67): include('/var/www/web116...') #15 {main} Weiß jemand abhilfe zu schaffen ??
Hallo, was sagt das Shopware Check Tool, sind alle Anforderungen erfüllt? LG Michael
Das Check tool meckert über disk\_free\_space 5 GB 0 5GB sind mehr als vorhanden und über suhosin.get.max\_value\_length 2000 0 When the "suhosin" PHP extension is loaded and the "get.max\_value\_length" is less than 2000, the Ext JS files cannot be loaded via GET request in the Shopware backend. This means that the Shopware backend can be partially uncached. Die 4.0.x lief vorher noch, habe mich aber für eine Neuinstallation entschieden, da ich ein wenig im Code rumgefummelt hatte
Hat denn keiner eine Lösung ??
Das wurde hier schon oft diskutiert, gib mal disk_free_space oben in die Suchabfrage ein.
