Fehler bei Erstinstallation Version 4.2.3.
Ich bekomme direkt nach der Sprachauswahl diese massive Fehlermeldung, obwohl die Checkprüfung grüne Lichter gezeigt hatte. Ich hatte zuvor Probleme bei den Upgrades und habe alles runtergeschmissen. War dann kurz bei OXID - dort hat/hätte alles funktioniert, aber Shopware scheint mir flexibler bei den Plugins zu sein. Daher der heutige Versuch einer Neuaufsetzung. Wer kann mir schnell helfen? Slim Application Error The application could not run because of the following error: Details Type: ErrorException Code: 2 Message: disk_free_space(): Value too large for defined data type File: /mnt/web2/a0/55/5643355/htdocs/install/src/lib/Shopware_Install_Requirements.php Line: 295 Trace #0 [internal function]: Slim\Slim::handleErrors(2, ‘disk_free_space…’, ‘/mnt/web2/a0/55…’, 295, Array) #1 /mnt/web2/a0/55/5643355/htdocs/install/src/lib/Shopware_Install_Requirements.php(295): disk_free_space(’/mnt/web2/a0/55…’) #2 /mnt/web2/a0/55/5643355/htdocs/install/src/lib/Shopware_Install_Requirements.php(76): Shopware_Install_Requirements->checkDiskFreeSpace() #3 /mnt/web2/a0/55/5643355/htdocs/install/src/lib/Shopware_Install_Requirements.php(38): Shopware_Install_Requirements->check(‘disk_free_space’) #4 /mnt/web2/a0/55/5643355/htdocs/install/src/lib/Shopware_Install_Requirements.php(61): Shopware_Install_Requirements->checkAll() #5 /mnt/web2/a0/55/5643355/htdocs/install/src/lib/Shopware_Install_Requirements.php(417): Shopware_Install_Requirements->getList() #6 /mnt/web2/a0/55/5643355/htdocs/install/src/app.php(122): Shopware_Install_Requirements->toArray() #7 [internal function]: {closure}() #8 /mnt/web2/a0/55/5643355/htdocs/engine/Library/Slim/Router.php(172): call_user_func_array(Object(Closure), Array) #9 /mnt/web2/a0/55/5643355/htdocs/engine/Library/Slim/Slim.php(1225): Slim\Router->dispatch(Object(Slim\Route)) #10 /mnt/web2/a0/55/5643355/htdocs/engine/Library/Slim/Middleware/Flash.php(86): Slim\Slim->call() #11 /mnt/web2/a0/55/5643355/htdocs/engine/Library/Slim/Middleware/MethodOverride.php(94): Slim\Middleware\Flash->call() #12 /mnt/web2/a0/55/5643355/htdocs/engine/Library/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call() #13 /mnt/web2/a0/55/5643355/htdocs/engine/Library/Slim/Slim.php(1176): Slim\Middleware\PrettyExceptions->call() #14 /mnt/web2/a0/55/5643355/htdocs/install/index.php(59): Slim\Slim->run() #15 {main}
Hallo, Entferne mal Zeile 24-26 aus der folgenden Datei https://github.com/ShopwareAG/shopware- … System.xml Die Meldung deutet darauf hin, dass der freie Speicher nicht geprüft werden kann. Durch due Entfernung des Abschnitts wird Disk Free Space nicht mehr überprüft. Vielleicht hilft das Sebastian
[quote=„Sebastian Klöpper“]Hallo, Entferne mal Zeile 24-26 aus der folgenden Datei https://github.com/ShopwareAG/shopware- … System.xml Die Meldung deutet darauf hin, dass der freie Speicher nicht geprüft werden kann. Durch due Entfernung des Abschnitts wird Disk Free Space nicht mehr überprüft. Vielleicht hilft das Sebastian[/quote] Habe die Datei gefunden und geändert. Hat leider nichts gebracht! Type: ErrorException Code: 2 Message: disk_free_space(): Value too large for defined data type File: /mnt/web2/a0/55/5643355/htdocs/install/src/lib/Shopware_Install_Requirements.php Line: 295 Trace #0 [internal function]: Slim\Slim::handleErrors(2, ‚disk_free_space…‘, ‚/mnt/web2/a0/55…‘, 295, Array) #1 /mnt/web2/a0/55/5643355/htdocs/install/src/lib/Shopware_Install_Requirements.php(295): disk_free_space(’/mnt/web2/a0/55…’) #2 /mnt/web2/a0/55/5643355/htdocs/install/src/lib/Shopware_Install_Requirements.php(76): Shopware_Install_Requirements->checkDiskFreeSpace() #3 /mnt/web2/a0/55/5643355/htdocs/install/src/lib/Shopware_Install_Requirements.php(38): Shopware_Install_Requirements->check(‚disk_free_space‘) #4 /mnt/web2/a0/55/5643355/htdocs/install/src/lib/Shopware_Install_Requirements.php(61): Shopware_Install_Requirements->checkAll() #5 /mnt/web2/a0/55/5643355/htdocs/install/src/lib/Shopware_Install_Requirements.php(417): Shopware_Install_Requirements->getList() #6 /mnt/web2/a0/55/5643355/htdocs/install/src/app.php(122): Shopware_Install_Requirements->toArray() #7 [internal function]: {closure}() #8 /mnt/web2/a0/55/5643355/htdocs/engine/Library/Slim/Router.php(172): call_user_func_array(Object(Closure), Array) #9 /mnt/web2/a0/55/5643355/htdocs/engine/Library/Slim/Slim.php(1225): Slim\Router->dispatch(Object(Slim\Route)) #10 /mnt/web2/a0/55/5643355/htdocs/engine/Library/Slim/Middleware/Flash.php(86): Slim\Slim->call() #11 /mnt/web2/a0/55/5643355/htdocs/engine/Library/Slim/Middleware/MethodOverride.php(94): Slim\Middleware\Flash->call() #12 /mnt/web2/a0/55/5643355/htdocs/engine/Library/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call() #13 /mnt/web2/a0/55/5643355/htdocs/engine/Library/Slim/Slim.php(1176): Slim\Middleware\PrettyExceptions->call() #14 /mnt/web2/a0/55/5643355/htdocs/install/index.php(59): Slim\Slim->run() #15 {main}
Hallo, habe mal kurz nach gegoogelt Message: disk_free_space(): Value too large for defined data type Das deutet darauf hin, dass der Wert zu groß für due Funktion ist. Also dein Webspace scheint so groß zu sein, dass diese Standardfunktion damit nicht mehr klar kommt. Bisher hatten wir so eine Meldung auch noch nicht :wink: Habe da so aktuell jetzt auch noch keinen Tipp bzw. Anpassung parat. Vllt. speziell mit dieser Meldung nochmal recherchieren. Im Notfall müsste man die Prüfung halt komplett überspringen /install/src/lib/Shopware_Install_Requirements.php Zeile 295
