my shopware account hasn’t any option where I can change shopware default theme.
Can anyone help me?
I’m facing a big problem
What do you want to do? By clicking on the existing one, you should see three little points, where you have the option to create a duplicate to work with it. In the extensions section you can also install new ones from the store.
