Shopware front-end
Hello
Now i have install shopware6 on my hosting
https://shopware.flex-webservice.com/
I want to start build a store , how can i edit theme or add my code ( HTML-CSS - JS )
in genral how can i build a store in easy way like this for EX: https://www.bike-discount.de/
hint : I have Install shopware local to on ubuntu using Git and Docker But i’m not too much familie with files and phpstorm …
i take a look , but this commands run on hosting ? (online webshop)
It´s all explained in the documentation link - you first need to create an independent theme, in which you can then derive from the default theme and you need to be familiar with twig.
I´d suggest you first take a look at the entire documentation.
