Hallo liebes Forum. Seit Stunden kämpfe ich mit dem Sofort Überweisung Plugin. Wenn ich den Vorgang abbreche und auf „zurück zum shop“ klicke erscheit folgende Fehlermeldung. Wo liegt hier der Fehler? Ups! An error has occurred! The following hints should help you. Syntax Error in template "/home/.sites/163/site3726643/web/engine/Shopware/Plugins/Community/Frontend/SofortPayment/Views/frontend/register/payment\_fieldset.tpl" on line 10 "{$smarty.block.parent}" $smarty.block is invalid in Smarty/sysplugins/smarty\_internal\_templatecompilerbase.php on line 657 [code]Stack trace: #0 Smarty/sysplugins/smarty_internal_compile_private_special_variable.php(97): Smarty_Internal_TemplateCompilerBase->trigger_template_error(’$smarty.block i…’) #1 Smarty/sysplugins/smarty_internal_templatecompilerbase.php(475): Smarty_Internal_Compile_Private_Special_Variable->compile(Array, Object(Smarty_Internal_SmartyTemplateCompiler), '[‚block‘][‚pare…‘, NULL, NULL) #2 Smarty/sysplugins/smarty_internal_templatecompilerbase.php(249): Smarty_Internal_TemplateCompilerBase->callTagCompiler(‚private_special…‘, Array, ‚[‚block‘][‚pare…‘) #3 Smarty/sysplugins/smarty_internal_templateparser.php(2713): Smarty_Internal_TemplateCompilerBase->compileTag(‚private_special…‘, Array, ‚[‚block‘][‚pare…‘) #4 Smarty/sysplugins/smarty_internal_templateparser.php(3101): Smarty_Internal_Templateparser->yy_r122() #5 Smarty/sysplugins/smarty_internal_templateparser.php(3201): Smarty_Internal_Templateparser->yy_reduce(122) #6 Smarty/sysplugins/smarty_internal_smartytemplatecompiler.php(105): Smarty_Internal_Templateparser->doParse(17, ‚}‘) #7 Smarty/sysplugins/smarty_internal_templatecompilerbase.php(192): Smarty_Internal_SmartyTemplateCompiler->doCompile(‘{block name=‚fr…‘) #8 Smarty/sysplugins/smarty_internal_compile_include.php(146): Smarty_Internal_TemplateCompilerBase->compileTemplate(Object(Enlight_Template_Default)) #9 Smarty/sysplugins/smarty_internal_templatecompilerbase.php(475): Smarty_Internal_Compile_Include->compile(Array, Object(Smarty_Internal_SmartyTemplateCompiler), Array, NULL, NULL) #10 Smarty/sysplugins/smarty_internal_templatecompilerbase.php(249): Smarty_Internal_TemplateCompilerBase->callTagCompiler(‚include‘, Array, Array) #11 Smarty/sysplugins/smarty_internal_templateparser.php(2388): Smarty_Internal_TemplateCompilerBase->compileTag(‚include‘, Array) #12 Smarty/sysplugins/smarty_internal_templateparser.php(3101): Smarty_Internal_Templateparser->yy_r36() #13 Smarty/sysplugins/smarty_internal_templateparser.php(3201): Smarty_Internal_Templateparser->yy_reduce(36) #14 Smarty/sysplugins/smarty_internal_smartytemplatecompiler.php(105): Smarty_Internal_Templateparser->doParse(10, ‚\n …‘) #15 Smarty/sysplugins/smarty_internal_templatecompilerbase.php(192): Smarty_Internal_SmartyTemplateCompiler->doCompile(‘\n\t
compileTemplate(Object(Enlight_Template_Default)) #26 Smarty/sysplugins/smarty_internal_templatebase.php(155): Smarty_Internal_Template->compileTemplateSource() #27 Enlight/View/Default.php(274): Smarty_Internal_TemplateBase->fetch() #28 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(216): Enlight_View_Default->render(Object(Enlight_Template_Default)) #29 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(242): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->renderTemplate(Object(Enlight_Template_Default)) #30 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->render() #31 [internal function]: Enlight_Controller_Plugins_ViewRenderer_Bootstrap->onPostDispatch(Object(Enlight_Controller_ActionEventArgs)) #32 Enlight/Event/Handler/Default.php(91): call_user_func(Array, Object(Enlight_Controller_ActionEventArgs)) #33 Enlight/Event/EventManager.php(211): Enlight_Event_Handler_Default->execute(Object(Enlight_Controller_ActionEventArgs)) #34 Enlight/Controller/Action.php(202): Enlight_Event_EventManager->notify(‚Enlight_Control…‘, Object(Enlight_Controller_ActionEventArgs)) #35 Enlight/Controller/Dispatcher/Default.php(524): Enlight_Controller_Action->dispatch(‚paymentAction‘) #36 Enlight/Controller/Front.php(227): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #37 Shopware/Kernel.php(143): Enlight_Controller_Front->dispatch() #38 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(490): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #39 Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #40 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(447): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #41 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(347): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true) #42 Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #43 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(211): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #44 Shopware/Components/HttpCache/AppCache.php(114): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #45 shopware.php(101): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #46 {main}[/code]
