Shopware Update von 4.3.6 auf 5.1.5 schlägt fehl
Hi zusammen,
leider schlägt das Shopware Update von Version 4.3.6 auf 5.1.5 fehl.
Das entsprechende Updatepaket habe ich eingespielt und die Installation über den Browser ausgeführt.
Es erscheint folgendes Stack Trace:
Type: ErrorException
Code: 2
Message: file_get_contents(/home/www/p123341/html/shopware/shopware5/engine/Shopware/Plugins/Default/Backend/HeidelActions/Bootstrap.php): failed to open stream: No such file or directory
File: /home/www/p123341/html/shopware/shopware5/recovery/update/src/DummyPluginFinder.php
Line: 80
Trace
#0 [internal function]: Slim\Slim::handleErrors(2, ‘file_get_conten…’, ‘/home/www/p1233…’, 80, Array)
#1 /home/www/p123341/html/shopware/shopware5/recovery/update/src/DummyPluginFinder.php(80): file_get_contents(’/home/www/p1233…’)
#2 /home/www/p123341/html/shopware/shopware5/recovery/update/src/DummyPluginFinder.php(57): Shopware\Recovery\Update\DummyPluginFinder->isDummyPlugin(’/home/www/p1233…’)
#3 /home/www/p123341/html/shopware/shopware5/recovery/update/src/Controller/CleanupController.php(100): Shopware\Recovery\Update\DummyPluginFinder->getDummyPlugins()
#4 /home/www/p123341/html/shopware/shopware5/recovery/update/src/app.php(159): Shopware\Recovery\Update\Controller\CleanupController->cleanupOldFiles()
#5 [internal function]: {closure}()
#6 /home/www/p123341/html/shopware/shopware5/recovery/common/vendor/slim/slim/Slim/Route.php(462): call_user_func_array(Object(Closure), Array)
#7 /home/www/p123341/html/shopware/shopware5/recovery/common/vendor/slim/slim/Slim/Slim.php(1326): Slim\Route->dispatch()
#8 /home/www/p123341/html/shopware/shopware5/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()
#9 /home/www/p123341/html/shopware/shopware5/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()
#10 /home/www/p123341/html/shopware/shopware5/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()
#11 /home/www/p123341/html/shopware/shopware5/recovery/common/vendor/slim/slim/Slim/Slim.php(1271): Slim\Middleware\PrettyExceptions->call()
#12 /home/www/p123341/html/shopware/shopware5/recovery/update/index.php(46): Slim\Slim->run()
#13 {main}
Weiß jemand Rat?
Vielen Dank und viele Grüße,
Chris
Du hast die Plugins vorher nicht deinstalliert (deaktivieren reicht nicht) ?
http://community.shopware.com/Update-Guide-Shopware-5.0-auf-Shopware-5.1_detail_1885_441.html
Mit dem automatischen Update Überprüfer im Backend sehen welche Plugins kompatibel sind und welche nicht. Alle die es nicht sind deinstallieren.
Danach am besten manuell updaten  http://community.shopware.com/_detail_1878.html
Das hat sich zwischenzeitlich erledigt, die Lösung lag im Foreignkeyreparatur Script von Shopware!
