I am using Arvixe Hosting, I have tried this manytimes,
Whenever i am installing shopware, and running after all first run and wizards and after login in backend, I am getting this error…
Please let me know why this is appearing ?
Attached a Screenshot also…
regards shafeeq
Oops! An error has occurred!
The following notes should help you.
Unable to load template snippet 'backend/swag_update/load.tpl' in engine/Library/Smarty/sysplugins/smarty_internal_templatebase.php on line 127
Stack trace:
#0 engine/Library/Enlight/View/Default.php(300): Smarty_Internal_TemplateBase->fetch()
#1 engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(216): Enlight_View_Default->render(Object(Enlight_Template_Default))
#2 engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(242): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->renderTemplate(Object(Enlight_Template_Default))
#3 engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->render()
#4 [internal function]: Enlight_Controller_Plugins_ViewRenderer_Bootstrap->onPostDispatch(Object(Enlight_Controller_ActionEventArgs))
#5 engine/Library/Enlight/Event/Handler/Default.php(91): call_user_func(Array, Object(Enlight_Controller_ActionEventArgs))
#6 engine/Library/Enlight/Event/EventManager.php(220): Enlight_Event_Handler_Default->execute(Object(Enlight_Controller_ActionEventArgs))
#7 engine/Library/Enlight/Controller/Action.php(236): Enlight_Event_EventManager->notify('Enlight_Control...', Object(Enlight_Controller_ActionEventArgs))
#8 engine/Library/Enlight/Controller/Dispatcher/Default.php(549): Enlight_Controller_Action->dispatch('loadAction')
#9 engine/Library/Enlight/Controller/Front.php(222): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#10 engine/Shopware/Kernel.php(215): Enlight_Controller_Front->dispatch()
#11 vendor/symfony/http-kernel/HttpCache/HttpCache.php(486): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#12 engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#13 vendor/symfony/http-kernel/HttpCache/HttpCache.php(253): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#14 engine/Shopware/Components/HttpCache/AppCache.php(105): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)
#15 shopware.php(122): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#16 {main}
