Shopware 6.5 Update Fehler
ich bekomme beim Shopware Update auf 6.5 (von 6.4.21) leider folgende Fehlermeldung:
PHP Fatal error:  Uncaught ReflectionException: Class "Shopware\Core\Framework\MessageQueue\Handler\AbstractMessageHandler" not found while loading "SwagMigrationAssistant\Migration\MessageQueue\Handler\ProcessMediaHandler". in /XXX/vendor/composer/ClassLoader.php:582
Stack trace:
#0 [internal function]: Composer\Autoload\ClassLoader->loadClass('...')
#1 /XXX/vendor/symfony/config/Resource/ClassExistenceResource.php(76): class_exists('...')
#2 /XXX/vendor/symfony/dependency-injection/ContainerBuilder.php(347): Symfony\Component\Config\Resource\ClassExistenceResource->isFresh(0)
#3 /XXX/vendor/symfony/messenger/DependencyInjection/MessengerPass.php(71): Symfony\Component\DependencyInjection\ContainerBuilder->getReflectionClass('...')
#4 /XXX/vendor/symfony/messenger/DependencyInjection/MessengerPass.php(55): Symfony\Component\Messenger\DependencyInjection\MessengerPass->registerHandlers(Object(Symfony\Component\DependencyInjection\ContainerBuilder), Array)
#5 /XXX/vendor/symfony/dependency-injection/Compiler/Compiler.php(73): Symfony\Component\Messenger\DependencyInjection\MessengerPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#6 /XXX/vendor/symfony/dependency-injection/ContainerBuilder.php(721): Symfony\Component\DependencyInjection\Compiler\Compiler->compile(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#7 /XXX/vendor/symfony/http-kernel/Kernel.php(487): Symfony\Component\DependencyInjection\ContainerBuilder->compile()
#8 /XXX/vendor/shopware/core/Kernel.php(166): Symfony\Component\HttpKernel\Kernel->initializeContainer()
#9 /XXX/bin/console(51): Shopware\Core\Kernel->boot()
#10 /XXX/vendor/autoload_runtime.php(24): {closure}(Array)
#11 /XXX/bin/console(15): require_once('...')
#12 {main}
  thrown in /XXX/vendor/composer/ClassLoader.php on line 582
Jemand eine Ahnung was falsch läuft?
Eine Datei bzw. Class fehlt. Kann es sein, dass nicht alle Dateien auf den Server kopiert wurden?
Update wurde über das Backend angestoßen. Bei Versuch das Update nochmal über den Browser anzustoßen kommt immer wieder diese Fehlermeldung.
Schau mal in dem Pfad nach… sollte in vendor sein: Vendor\Shopware\Core\Framework\MessageQueue\Handler\AbstractMessageHandler.php oder im Plugin.
Falls die Datei nicht vorhanden ist, dann am besten das Update neu installieren lassen oder die Dateien manuell auf den Server kopieren und dann erneut versuchen.
Danke. Der komplette Ordner „Handler“ war nicht vorhanden?
Habe ihn jetzt aus einer anderen Installation kopiert. Führt aber leider nur zur nächsten Fehlermeldung:
PHP Fatal error:  Uncaught Symfony\Component\DependencyInjection\Exception\ServiceNotFoundException: The service "SwagMigrationAssistant\DataProvider\Provider\GenerateDocumentProvider" has a dependency on a non-existent service "Shopware\Core\Checkout\Document\FileGenerator\FileGeneratorRegistry". Did you mean this: "Shopware\Core\Checkout\Document\Renderer\DocumentRendererRegistry"? in /XXX/vendor/symfony/dependency-injection/Compiler/CheckExceptionOnInvalidReferenceBehaviorPass.php:83
Was ist mit dem Update los? Die 6.4.21 Installation war bis auf zwei Plugins unverändert und ein paar Artikel waren testweise eingespielt.
Ich glaube, beim Schreiben der Update-Dateien gab es bei deinem Update Probleme, so dass nun nichts mehr wirklich funktioniert. Wie gesagt, am besten von Shopware Changelog | Shopware die Update-Dateien ziehen und neu versuchen.
