Shopware 6.5.0.0 updating issue
currently we are running on shopware 6.4.20.2 and we want to update to 6.5.0.0. We tried to update the shopware by deactivating all the plugins and started the process, when we try to update , shopware’s update process returing as unsuccessful. We have a sales|_channel called netherlands, because of that we are not able to deactivate one of the plugin called „shopware language pack“, but we deactivated by removing some of the entires in the Database, still this updating issue is persisting.
„exception“ => ErrorException {
#message: „User Deprecated: Since symfony/messenger 6.2: Implementing „Symfony\Component\Messenger\Handler\MessageSubscriberInterface“ is deprecated, use the „Symfony\Component\Messenger\Attribute\AsMessageHandler“ attribute instead.“
#code: 0
#file: „/var/www/vhosts/implify.de/test3.implify.de/vendor/symfony/messenger/DependencyInjection/MessengerPass.php“
#line: 209
#severity: E_USER_DEPRECATED
trace: {
/var/www/vhosts/implify.de/test3.implify.de/vendor/symfony/messenger/DependencyInjection/MessengerPass.php:209 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/symfony/messenger/DependencyInjection/MessengerPass.php:83 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/symfony/messenger/DependencyInjection/MessengerPass.php:58 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/symfony/dependency-injection/Compiler/Compiler.php:80 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/symfony/dependency-injection/ContainerBuilder.php:767 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/symfony/http-kernel/Kernel.php:506 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/core/Kernel.php:166 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/symfony/http-kernel/Kernel.php:144 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/core/Kernel.php:230 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/core/Maintenance/System/Command/SystemUpdateFinishCommand.php:140 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/core/Maintenance/System/Command/SystemUpdateFinishCommand.php:70 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/symfony/console/Command/Command.php:326 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/symfony/console/Application.php:1081 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/symfony/framework-bundle/Console/Application.php:91 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/symfony/console/Application.php:320 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/symfony/framework-bundle/Console/Application.php:80 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/symfony/console/Application.php:174 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/symfony/runtime/Runner/Symfony/ConsoleApplicationRunner.php:54 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/autoload_runtime.php:29 { …}
/var/www/vhosts/implify.de/test3.implify.de/bin/console:15 {
› require_once DIR . ‚/…/vendor/autoload_runtime.php‘;
#message: „“"
User Deprecated: Nesting transactions without enabling savepoints is deprecated.\n
Call Doctrine\DBAL\Connection::setNestTransactionsWithSavepoints(true) to enable savepoints. (Connection.php:1380 called by Connection.php:1273, Deprecate transaction nesting without savepoints by greg0ire · Pull Request #5383 · doctrine/dbal · GitHub, package doctrine/dbal)
#code: 0
#file: „/var/www/vhosts/implify.de/test3.implify.de/vendor/doctrine/deprecations/lib/Doctrine/Deprecations/Deprecation.php“
#line: 209
trace: {
/var/www/vhosts/implify.de/test3.implify.de/vendor/doctrine/deprecations/lib/Doctrine/Deprecations/Deprecation.php:209 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/doctrine/deprecations/lib/Doctrine/Deprecations/Deprecation.php:107 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/doctrine/dbal/src/Connection.php:1380 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/doctrine/dbal/src/Connection.php:1273 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/core/Framework/DataAbstractionLayer/Doctrine/RetryableTransaction.php:34 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/core/Framework/DataAbstractionLayer/Doctrine/RetryableTransaction.php:21 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/core/Framework/DataAbstractionLayer/Doctrine/MultiInsertQueryQueue.php:79 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/core/Framework/DataAbstractionLayer/Dbal/EntityWriteGateway.php:226 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/core/Framework/DataAbstractionLayer/Dbal/EntityWriteGateway.php:110 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/doctrine/dbal/src/Connection.php:1275 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/core/Framework/DataAbstractionLayer/Dbal/EntityWriteGateway.php:111 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/core/Framework/DataAbstractionLayer/Write/EntityWriter.php:225 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/core/Framework/DataAbstractionLayer/Write/EntityWriter.php:147 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/core/Framework/DataAbstractionLayer/VersionManager.php:100 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/core/Framework/DataAbstractionLayer/EntityRepository.php:124 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/core/Framework/MessageQueue/ScheduledTask/Registry/TaskRegistry.php:145 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/core/Framework/MessageQueue/ScheduledTask/Registry/TaskRegistry.php:68 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/core/Framework/MessageQueue/ScheduledTask/Registry/TaskRegistry.php:41 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/core/Framework/MessageQueue/Subscriber/UpdatePostFinishSubscriber.php:33 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/symfony/event-dispatcher/EventDispatcher.php:260 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/symfony/event-dispatcher/EventDispatcher.php:220 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/symfony/event-dispatcher/EventDispatcher.php:56 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/core/Content/Flow/Dispatching/FlowDispatcher.php:47 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/core/Framework/Webhook/WebhookDispatcher.php:67 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/core/Framework/Event/NestedEventDispatcher.php:31 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/core/Maintenance/System/Command/SystemUpdateFinishCommand.php:97 { …}
#message: „User Deprecated: Since shopware/core : Method „Shopware\Core\Content\Media\Message\GenerateThumbnailsMessage::Shopware\Core\Content\Media\Message\GenerateThumbnailsMessage::withContext()“ is deprecated and will be removed in v6.6.0.0.“
#code: 0
#file: „/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/core/Framework/Feature.php“
#line: 186
trace: {
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/core/Framework/Feature.php:186 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/core/Content/Media/Message/GenerateThumbnailsMessage.php:58 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/core/Content/Media/File/FileSaver.php:109 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/storefront/Theme/ThemeLifecycleService.php:397 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/storefront/Theme/ThemeLifecycleService.php:78 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/storefront/Theme/ThemeLifecycleService.php:55 { …}
/var/www/vhosts/implify.de/test3.implify.de/vendor/shopware/storefront/Theme/Subscriber/UpdateSubscriber.php:51 { …}
#code: „23000“
#file: „/var/www/vhosts/implify.de/test3.implify.de/vendor/doctrine/dbal/src/Driver/PDO/Connection.php“
#line: 32
+errorInfo: [
„23000“,
1452,
„Cannot add or update a child row: a foreign key constraint fails (test3.system_config, CONSTRAINT fk.system_config.sales_channel_id FOREIGN KEY (sales_channel_id) REFERENCES sales_channel (id) ON DELETE CASCADE ON UPDATE CASCADE)“
How can we fix this issue? Thanks in advance.
Thanks,
1 „Gefällt mir“
