Shopware 4.2.1
Hab z.B. an den rechten nichts geändert nur den jeweilgigen Ordnern den Besitzer zugewiesen und das wars.
[quote=“Patrick Schücker”]Hallo Community, auf 4.2.0 folgt 4.2.1 http://wiki.shopware.de/Downloads_cat_448.html Falls ihr Probleme damit feststellt, bitte erstellt direkt in unserem Bugtracker ein Ticket. So bekommen unsere Entwickler direkt mit, wenn etwas nicht so ist, wie es sein soll. Viele Grüße aus dem Münsterland Patrick Schücker[/quote] I apologize for writing in English but I cannot speak German and I cannot find any information about the error I’m getting (not in German nor in English). I don’t know if it is a bug, if you tell me so, I will add it to the Bugtracker. Each time I try to install a plugin in a clean installation of shopware 4.1.2 I get the following message: Plugin-Manager Plugin konnte nicht erfolgreich installiert werden. DateTime::__construct(): Failed to parse time string (17/02/2014 12:39:51) at position 0 (1): Unexpected character Maybe it has do to with some kind of permissions but I’m not sure which folders do I have to grant permissions to. In shopware 4.2.0 I could install all the plugins properly but I had to uninstall the amazon payment plugin and after that I got the same error as in shopware 4.2.1 and never got to install any plugin again. Thanks for your help.
Yes it has todo with your persmissions, pls check your www user if he is the owner of the folders.
Thanks sakura13, I thought my permissions were properly set because in the system requirements of the installation (step 2) everything was ok. I’ve checked the permissions, I’ve installed shopware 4.2.1 in localhost and two different hostings and made several tests but I cannot install plugins yet. I’m at a loss.
Hallo, da ich öfter Shopware Mitarbeiter antworten sehe, hier mal die Frage, ob nicht auf meinen Post geantwortet werden könnte wegen der Varianten Probleme … administration-f55/varianten-loschen-sortieren-fehlerhaft-t18741.html Ich stehe kurz davor, zwei neue Shops incl. einem Subshop mit Lizenz (also Kauf) aufsetzen zu müssen, kann das aber nicht mit dem bestehenden Problemen. Und ich möchte ungern das System wechseln müssen … Danke.
[quote=“budodan”][quote=“Marcel S”]Hi, dann solltest du herausfinden wie man php bei dir auf der Console ausführt. Eventuell kann dir hier dein Hoster weiterhelfen :wink: Vg, marcel[/quote] Habe beim Support angerufen. Dort hat man mir sogar mehr Auskunft geben können. Es fehlt wohl ein Verzeichnis/Datei im Ordner engine/Library und darunter soll wohl “Slim/Slim.php” fehlen. Weder bei mir auf dem Server, noch in der Download-Datei existiert Slim/Slim.php. Weitere Ideen? Vielen Dank im Voraus.[/quote] Könnten wir vielleicht den Grund des Problems mit Slim.php auch erfahren? Das wäre sehr nett :slight_smile:
