Shop nicht mehr zu erreichen nach Deinstallation von ERP Shopware
Hallo, ich komme nicht weiter.
Habe eine Fehlermeldungung in beiden Subshops (www.karikaturwelt.de)
Property Shopware\Models\Attribute\Article::$viisonPhysicalStockForSale does not exist in vendor/doctrine/common/lib/Doctrine/Common/Persistence/Mapping/RuntimeReflectionService.php on line 80
Stack trace:
 #0 vendor/doctrine/common/lib/Doctrine/Common/Persistence/Mapping/RuntimeReflectionService.php(80): ReflectionProperty-\>\_\_construct('Shopware\\Models...', 'viisonPhysicalS...') #1 vendor/doctrine/orm/lib/Doctrine/ORM/Mapping/ClassMetadataInfo.php(959): Doctrine\Common\Persistence\Mapping\RuntimeReflectionService-\>getAccessibleProperty('Shopware\\Models...', 'viisonPhysicalS...') #2 vendor/doctrine/orm/lib/Doctrine/ORM/Mapping/ClassMetadataFactory.php(721): Doctrine\ORM\Mapping\ClassMetadataInfo-\>wakeupReflection(Object(Doctrine\Common\Persistence\Mapping\RuntimeReflectionService)) #3 vendor/doctrine/common/lib/Doctrine/Common/Persistence/Mapping/AbstractClassMetadataFactory.php(214): Doctrine\ORM\Mapping\ClassMetadataFactory-\>wakeupReflection(Object(Doctrine\ORM\Mapping\ClassMetadata), Object(Doctrine\Common\Persistence\Mapping\RuntimeReflectionService)) #4 vendor/doctrine/orm/lib/Doctrine/ORM/EntityManager.php(281): Doctrine\Common\Persistence\Mapping\AbstractClassMetadataFactory-\>getMetadataFor('Shopware\\Models...') #5 engine/Library/Doctrine/ORM/Persisters/Entity/BasicEntityPersister.php(1255): Doctrine\ORM\EntityManager-\>getClassMetadata('Shopware\\Models...') #6 engine/Library/Doctrine/ORM/Persisters/Entity/BasicEntityPersister.php(1100): Doctrine\ORM\Persisters\Entity\BasicEntityPersister-\>getSelectColumnsSQL() #7 engine/Library/Doctrine/ORM/Persisters/Entity/BasicEntityPersister.php(740): Doctrine\ORM\Persisters\Entity\BasicEntityPersister-\>getSelectSQL(Array, NULL, NULL, 1, NULL, NULL) #8 vendor/doctrine/orm/lib/Doctrine/ORM/EntityRepository.php(196): Doctrine\ORM\Persisters\Entity\BasicEntityPersister-\>load(Array, NULL, NULL, Array, NULL, 1, NULL) #9 engine/Shopware/Plugins/Community/Frontend/SwagLiveShopping/Bootstrap.php(571): Doctrine\ORM\EntityRepository-\>findOneBy(Array) #10 engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Frontend\_SwagLiveShopping\_Bootstrap-\>onUpdateArticle(Object(Enlight\_Hook\_HookArgs)) #11 engine/Library/Enlight/Event/EventManager.php(214): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Hook\_HookArgs)) #12 engine/Library/Enlight/Hook/HookManager.php(178): Enlight\_Event\_EventManager-\>notify('sBasket::sUpdat...', Object(Enlight\_Hook\_HookArgs)) #13 var/cache/production\_201707131430/proxies/sBasketProxy.php(31): Enlight\_Hook\_HookManager-\>executeHooks(Object(Shopware\_Proxies\_sBasketProxy), 'sUpdateArticle', Object(Enlight\_Hook\_HookArgs)) #14 engine/Shopware/Core/sBasket.php(1054): Shopware\_Proxies\_sBasketProxy-\>sUpdateArticle('16067', '1') #15 var/cache/production\_201707131430/proxies/sBasketProxy.php(6): sBasket-\>sGetBasket() #16 engine/Library/Enlight/Hook/HookManager.php(186): Shopware\_Proxies\_sBasketProxy-\>executeParent('sGetBasket', Array) #17 var/cache/production\_201707131430/proxies/sBasketProxy.php(24): Enlight\_Hook\_HookManager-\>executeHooks(Object(Shopware\_Proxies\_sBasketProxy), 'sGetBasket', Object(Enlight\_Hook\_HookArgs)) #18 engine/Shopware/Plugins/Community/Frontend/BestitAmazonPay/Bootstrap.php(2163): Shopware\_Proxies\_sBasketProxy-\>sGetBasket() #19 engine/Shopware/Plugins/Community/Frontend/BestitAmazonPay/Bootstrap.php(2070): Shopware\_Plugins\_Frontend\_BestitAmazonPay\_Bootstrap-\>checkRiskmanagement() #20 engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Frontend\_BestitAmazonPay\_Bootstrap-\>onPostDispatch(Object(Enlight\_Controller\_ActionEventArgs)) #21 engine/Library/Enlight/Event/EventManager.php(214): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Controller\_ActionEventArgs)) #22 engine/Library/Enlight/Controller/Action.php(184): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_ActionEventArgs)) #23 engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight\_Controller\_Action-\>dispatch('indexAction') #24 engine/Library/Enlight/Controller/Front.php(223): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #25 engine/Shopware/Kernel.php(182): Enlight\_Controller\_Front-\>dispatch() #26 vendor/symfony/http-kernel/HttpCache/HttpCache.php(491): Shopware\Kernel-\>handle(Object(Enlight\_Controller\_Request\_RequestHttp), 1, true) #27 engine/Shopware/Components/HttpCache/AppCache.php(266): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #28 vendor/symfony/http-kernel/HttpCache/HttpCache.php(448): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #29 vendor/symfony/http-kernel/HttpCache/HttpCache.php(344): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>fetch(Object(Symfony\Component\HttpFoundation\Request), true) #30 engine/Shopware/Components/HttpCache/AppCache.php(187): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true) #31 vendor/symfony/http-kernel/HttpCache/HttpCache.php(210): Shopware\Components\HttpCache\AppCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true) #32 engine/Shopware/Components/HttpCache/AppCache.php(114): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #33 shopware.php(117): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #34 {main}
Kann mir da einer weiterhelfen?
Hallo kaddi,
Wo genau bekommst Du diese Meldung in Deinen Subshops?
Ist die Deinstallation vollständig durchgelaufen?
Welche Version von dem Plugin hattest Du vorher aktiv?
Du könntest hier versuchen unter var/cache/ den aktuellen production Ordner zu löschen / umzubennen,
sodass der Cache hier vollständig neu aufgebaut wird.
