Setting different VAT per sub shop
Hi there,
I have different sub shops for different countries and I’d like to set different VAT depending on the sub shop but as I can see only one VAT option can be assigned to a product, is there a way to have different VAT options without duplicating the product?
Thanks
Hi Roberto,
you can add diffrend values in the TAX settings. There you have a option (on the right side) to add Taxes per Country, Area or State.
kind regards,
Simeon
Hello,
Thanks for your reply, I have been looking into this but still not working. Assume I am a UK customer visiting the UK site
Following your suggestions I set up a rule for General UK customer group - customers in Great Britain are charge 20% VAT
1 - After adding the product to the cart, the product price is correct 17.99; the tax charged is showing at 23% instead of 20% but I assume this is because user it’s not logged in yet
2 - I proceed to checkout and select Great Britain as my address
3 - Now the price breakdown is showing the correct VAT rate but the product price has changed
4 - Final step at checkout - the product price is 17.55 instead of 17.99 (Shopware understands that 17.99 is price of inclusive of 23% so now it calculates the net price and ads 20%, therefore, the prices is less)
5 - Still logged in, if I decide to abandon the checkout and go back to browsing the products, the prices are now showing inclusive of 20% VAT. They are lower than what want to charge our customers.
Kind regards
Hello Roberto,
Yes you are right. However, this is the default behavior.
Otherwise you have to work with plugins.
Kind Regards,
Simeon
Hi Simeon,
Any plugin you can recommend and personally are using?
I have been investigating this issue for a client for some time - and couldn’t find a trustworthy one.
Yours,
Stefan
