Da in der Version 5.2.8 der Import einen Fehler hat wollte ich gleichzeitig noch die version 5.1.6 installieren die diesen Fehler nicht hat.
Nach dem eingeben des Adminspasswortes kommt dann
Slim Application Error
Type: RuntimeException
Message: Could not get id for default template
File: /var/www/clients/client3/web5/web/_shopware_51/recovery/install/src/Service/ThemeService.php
Line: 78
Trace
#0 /var/www/clients/client3/web5/web/_shopware_51/recovery/install/src/Service/ThemeService.php(63): Shopware\Recovery\Install\Service\ThemeService->getResponsiveTemplateId()
#1 /var/www/clients/client3/web5/web/_shopware_51/recovery/install/src/app.php(438): Shopware\Recovery\Install\Service\ThemeService->activateResponsiveTheme()
#2 [internal function]: {closure}()
#3 /var/www/clients/client3/web5/web/_shopware_51/recovery/common/vendor/slim/slim/Slim/Route.php(462): call_user_func_array(Object(Closure), Array)
#4 /var/www/clients/client3/web5/web/_shopware_51/recovery/common/vendor/slim/slim/Slim/Slim.php(1326): Slim\Route->dispatch()
#5 /var/www/clients/client3/web5/web/_shopware_51/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()
#6 /var/www/clients/client3/web5/web/_shopware_51/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()
#7 /var/www/clients/client3/web5/web/_shopware_51/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()
#8 /var/www/clients/client3/web5/web/_shopware_51/recovery/common/vendor/slim/slim/Slim/Slim.php(1271): Slim\Middleware\PrettyExceptions->call()
#9 /var/www/clients/client3/web5/web/_shopware_51/recovery/install/index.php(74): Slim\Slim->run()
#10 {main}
Die 5.2.8 ließ sich problemlos installieren??
