Hi, I’m trying to make a field within my Shopware checkout process optional… but I can’t for the life of me figure out a simple enough way of doing this. Has anyone had any experience with this before?
Take a look at this Plugin: https://github.com/hostianer/HostiConditions Maybe it helps you to figured out how it works. This little Plugin adds a secound checkbox after the “terms of use” checkbox. Make also sure you read the dev docs here -> https://developers.shopware.com/developers-guide/ https://developers.shopware.com/designers-guide/
