Hallo liebe Shopware Community
Als ich heute morgen ins Backend wollte tritt auf einmal die Fehlermeldung auf:
Die nachfolgenden Hinweise sollten dir weiterhelfen.
Plugin „Auth“ not found failure in engine/Library/Enlight/Plugin/PluginCollection.php on line 117
Stack trace:
#0 engine/Library/Enlight/Plugin/Namespace/Config.php(83): Enlight\_Plugin\_PluginCollection-\>load('Auth', true) #1 engine/Library/Enlight/Plugin/PluginCollection.php(97): Enlight\_Plugin\_Namespace\_Config-\>load('Auth', true) #2 engine/Library/Enlight/Plugin/PluginCollection.php(131): Enlight\_Plugin\_PluginCollection-\>get('Auth', true) #3 engine/Shopware/Controllers/Backend/Index.php(48): Enlight\_Plugin\_PluginCollection-\>\_\_call('Auth', Array) #4 engine/Shopware/Controllers/Backend/Index.php(48): Shopware\_Components\_Plugin\_Namespace-\>Auth() #5 engine/Library/Enlight/Class.php(74): Shopware\_Controllers\_Backend\_Index-\>init() #6 engine/Library/Enlight/Controller/Action.php(101): Enlight\_Class-\>\_\_construct() #7 engine/Library/Enlight/Controller/Dispatcher/Default.php(504): Enlight\_Controller\_Action-\>\_\_construct(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #8 engine/Library/Enlight/Controller/Front.php(226): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #9 engine/Shopware/Kernel.php(175): Enlight\_Controller\_Front-\>dispatch() #10 vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #11 engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #12 vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #13 engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #14 shopware.php(101): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #15 {main}
Komischerweise aber habe ich die letzten Tage nichts am Shop gemacht. Weder Artikel hinzugefügt noch sonst irgend etwas geändert. Woran kann das liegen?
Der letzte Aufruf des Backends ging reibungslos von statten.
Hinzu kommt, dass das Fronend funktioniert.
Kann mir jemand helfen?
