Unser Shop funktioniert auf einmal nicht mehr (Domain = www. e-rauchershop.de und es wird folgender Fehler angezeigt: Ups! Ein Fehler ist aufgetreten! Die nachfolgenden Hinweise sollten Ihnen weiterhelfen. An exception occurred while executing ‘SELECT s0_.id AS id0, s0_.main_id AS main_id1, s0_.category_id AS category_id2, s0_.name AS name3, s0_.title AS title4, s0_.position AS position5, s0_.host AS host6, s0_.base_path AS base_path7, s0_.base_url AS base_url8, s0_.hosts AS hosts9, s0_.secure AS secure10, s0_.always_secure AS always_secure11, s0_.secure_host AS secure_host12, s0_.secure_base_path AS secure_base_path13, s0_.default AS default14, s0_.active AS active15, s0_.customer_scope AS customer_scope16, s1_.id AS id17, s1_.main_id AS main_id18, s1_.category_id AS category_id19, s1_.name AS name20, s1_.title AS title21, s1_.position AS position22, s1_.host AS host23, s1_.base_path AS base_path24, s1_.base_url AS base_url25, s1_.hosts AS hosts26, s1_.secure AS secure27, s1_.always_secure AS always_secure28, s1_.secure_host AS secure_host29, s1_.secure_base_path AS secure_base_path30, s1_.default AS default31, s1_.active AS active32, s1_.customer_scope AS customer_scope33, s2_.id AS id34, s2_.locale AS locale35, s2_.language AS language36, s2_.territory AS territory37, s3_.id AS id38, s3_.currency AS currency39, s3_.name AS name40, s3_.standard AS standard41, s3_.factor AS factor42, s3_.templatechar AS templatechar43, s3_.symbol_position AS symbol_position44, s3_.position AS position45, s4_.id AS id46, s4_.template AS template47, s4_.name AS name48, s4_.description AS description49, s4_.author AS author50, s4_.license AS license51, s4_.esi AS esi52, s4_.style_support AS style_support53, s4_.emotion AS emotion54, s4_.version AS version55, s4_.plugin_id AS plugin_id56, s5_.id AS id57, s5_.currency AS currency58, s5_.name AS name59, s5_.standard AS standard60, s5_.factor AS factor61, s5_.templatechar AS templatechar62, s5_.symbol_position AS symbol_position63, s5_.position AS position64, s0_.main_id AS main_id65, s0_.template_id AS template_id66, s0_.document_template_id AS document_template_id67, s0_.category_id AS category_id68, s0_.locale_id AS locale_id69, s0_.currency_id AS currency_id70, s0_.customer_group_id AS customer_group_id71, s0_.fallback_id AS fallback_id72, s1_.main_id AS main_id73, s1_.template_id AS template_id74, s1_.document_template_id AS document_template_id75, s1_.category_id AS category_id76, s1_.locale_id AS locale_id77, s1_.currency_id AS currency_id78, s1_.customer_group_id AS customer_group_id79, s1_.fallback_id AS fallback_id80, s4_.plugin_id AS plugin_id81 FROM s_core_shops s0_ LEFT JOIN s_core_shops s1_ ON s0_.main_id = s1_.id LEFT JOIN s_core_locales s2_ ON s0_.locale_id = s2_.id LEFT JOIN s_core_currencies s3_ ON s0_.currency_id = s3_.id LEFT JOIN s_core_templates s4_ ON s0_.template_id = s4_.id LEFT JOIN s_core_shop_currencies s6_ ON s0_.id = s6_.shop_id LEFT JOIN s_core_currencies s5_ ON s5_.id = s6_.currency_id LEFT JOIN s_core_shop_pages s8_ ON s0_.id = s8_.shop_id LEFT JOIN s_cms_static_groups s7_ ON s7_.id = s8_.group_id LEFT JOIN s_core_customergroups s9_ ON s0_.customer_group_id = s9_.id LEFT JOIN s_core_templates s10_ ON s1_.template_id = s10_.id LEFT JOIN s_core_shop_currencies s12_ ON s1_.id = s12_.shop_id LEFT JOIN s_core_currencies s11_ ON s11_.id = s12_.currency_id WHERE s0_.active = 1 AND s0_.id = ? ORDER BY s0_.main_id ASC, s0_.position ASC, s5_.position ASC, s5_.id ASC’ with params [“1”]: SQLSTATE[HY000]: General error: 1030 Got error 28 from storage engine in vendor/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php on line 91 Stack trace: #0 vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(701): Doctrine\DBAL\DBALException::driverExceptionDuringQuery(Object(PDOException), ‘SELECT s0_.id A…’, Array) #1 vendor/doctrine/orm/lib/Doctrine/ORM/Query/Exec/SingleSelectExecutor.php(50): Doctrine\DBAL\Connection->executeQuery(‘SELECT s0_.id A…’, Array, Array, NULL) #2 vendor/doctrine/orm/lib/Doctrine/ORM/Query.php(286): Doctrine\ORM\Query\Exec\SingleSelectExecutor->execute(Object(Doctrine\DBAL\Connection), Array, Array) #3 vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(794): Doctrine\ORM\Query->_doExecute() #4 vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(612): Doctrine\ORM\AbstractQuery->execute(NULL, NULL) #5 Shopware/Models/Shop/Repository.php(250): Doctrine\ORM\AbstractQuery->getOneOrNullResult() #6 Shopware/Plugins/Default/Core/Router/Bootstrap.php(101): Shopware\Models\Shop\Repository->getActiveById(‘1’) #7 Enlight/Event/Handler/Plugin.php(149): Shopware_Plugins_Core_Router_Bootstrap->onRouteStartup(Object(Enlight_Controller_EventArgs)) #8 Enlight/Event/EventManager.php(211): Enlight_Event_Handler_Plugin->execute(Object(Enlight_Controller_EventArgs)) #9 Enlight/Controller/Front.php(170): Enlight_Event_EventManager->notify(‘Enlight_Control…’, Object(Enlight_Controller_EventArgs)) #10 Shopware/Kernel.php(141): Enlight_Controller_Front->dispatch() #11 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(473): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #12 Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #13 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(430): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #14 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(330): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true) #15 Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #16 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(194): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #17 Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #18 shopware.php(91): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #19 {main}
Was können wir tun? Woran kann es liegen?
Hallo, wahrscheinlich steht nicht genügend Speicherplatz für die DB oder den Server insgesamt zur Verfügung. Wie voll ist denn die Festplatte?
Haben Webspace von 200GB davon ist nicht mal 1 GB belegt. Geht es um den Speicherplatz oder einen Anderen?
Ich kann deinen Shop aber aufrufen und bekomme diesen ohne Fehlermeldung angezeigt!
Anscheinend hat unser Hoster ein Problem beseitigt oder es lag an den php.ini die ich eingestellt habe!
Trotzdem vielen Dank
