habe mich vorhin gewundert warum es nur so wenige Bestellunge diese Wochenende gab und jetzt gesehen, dass alle SubShops (auch die Hauptseite) bis auf .it, weiß/leer sind. Backend funktioniert ganz normal. Kann jemand hiermit etwas anfangen?
[2019-12-01 16:31:34] core.ERROR: SmartyCompilerException in /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php:657 Stack trace:
#0 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_templateparser.php(3144): Smarty_Internal_TemplateCompilerBase->trigger_template_error()
#1 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_templateparser.php(3209): Smarty_Internal_Templateparser->yy_syntax_error(10, ‘\xC2’)
#2 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_smartytemplatecompiler.php(105): Smarty_Internal_Templateparser->doParse(10, ‘\xC2’)
#3 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(192): Smarty_Internal_SmartyTemplateCompiler->doCompile(’{block name="fr…’)
#4 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_compile_include.php(146): Smarty_Internal_TemplateCompilerBase->compileTemplate(Object(Enlight_Template_Default))
#5 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(465): Smarty_Internal_Compile_Include->compile(Array, Object(Smarty_Internal_SmartyTemplateCompiler), Array, NULL, NULL)
#6 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(249): Smarty_Internal_TemplateCompilerBase->callTagCompiler(‘include’, Array, Array)
#7 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_templateparser.php(2388): Smarty_Internal_TemplateCompilerBase->compileTag(‘include’, Array)
#8 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_templateparser.php(3101): Smarty_Internal_Templateparser->yy_r36()
#9 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_templateparser.php(3201): Smarty_Internal_Templateparser->yy_reduce(36)
#10 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_smartytemplatecompiler.php(105): Smarty_Internal_Templateparser->doParse(10, ‘\n              …’)
#11 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(192): Smarty_Internal_SmartyTemplateCompiler->doCompile(’\n{if !$tlsDisab…’)
#12 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_compile_include.php(146): Smarty_Internal_TemplateCompilerBase->compileTemplate(Object(Enlight_Template_Default))
#13 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(475): Smarty_Internal_Compile_Include->compile(Array, Object(Smarty_Internal_SmartyTemplateCompiler), Array, NULL, NULL)
#14 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(249): Smarty_Internal_TemplateCompilerBase->callTagCompiler(‘include’, Array, Array)
#15 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_templateparser.php(2388): Smarty_Internal_TemplateCompilerBase->compileTag(‘include’, Array)
#16 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_templateparser.php(3101): Smarty_Internal_Templateparser->yy_r36()
#17 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_templateparser.php(3201): Smarty_Internal_Templateparser->yy_reduce(36)
#18 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_smartytemplatecompiler.php(105): Smarty_Internal_Templateparser->doParse(10, ‘\n    ‘)
#19 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(192): Smarty_Internal_SmartyTemplateCompiler->doCompile(’\n    \n    {bloc…’)
#20 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_compile_block.php(191): Smarty_Internal_TemplateCompilerBase->compileTemplate(Object(Smarty_Internal_Template))
#21 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_compile_block.php(255): Smarty_Internal_Compile_Block::compileChildBlock(Object(Smarty_Internal_SmartyTemplateCompiler), ‘frontend_index_…’)
#22 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(465): Smarty_Internal_Compile_Blockclose->compile(Array, Object(Smarty_Internal_SmartyTemplateCompiler), Array, NULL, NULL)
#23 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(249): Smarty_Internal_TemplateCompilerBase->callTagCompiler(‘blockclose’, Array, Array)
#24 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_templateparser.php(2493): Smarty_Internal_TemplateCompilerBase->compileTag(‘blockclose’, Array)
#25 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_templateparser.php(3101): Smarty_Internal_Templateparser->yy_r58()
#26 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_templateparser.php(3201): Smarty_Internal_Templateparser->yy_reduce(58)
#27 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_smartytemplatecompiler.php(105): Smarty_Internal_Templateparser->doParse(10, ‘\n\n            ‘)
#28 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(192): Smarty_Internal_SmartyTemplateCompiler->doCompile(’{block name="fr…’)
#29 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_template.php(187): Smarty_Internal_TemplateCompilerBase->compileTemplate(Object(Enlight_Template_Default))
#30 /var/www/xxx-live/public_html/engine/Library/Smarty/sysplugins/smarty_internal_templatebase.php(155): Smarty_Internal_Template->compileTemplateSource()
#31 /var/www/xxx-live/public_html/engine/Library/Enlight/View/Default.php(295): Smarty_Internal_TemplateBase->fetch()
#32 /var/www/xxx-live/public_html/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(212): Enlight_View_Default->render(Object(Enlight_Template_Default))
#33 /var/www/xxx-live/public_html/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(238): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->renderTemplate(Object(Enlight_Template_Default))
#34 /var/www/xxx-live/public_html/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(132): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->render()
