Newsletterverand nicht möglich
Hallo Forum-User,
im Forum konnte ich bisher keine uns helfende Lösung finden. Beim Versenden unserer Newsletter über den intelligenten Newsletter kommt es immer wieder zu nachstehender Fehlermeldung
directory ‘/html/shopware/testserver/index.tpl’ not allowed by security setting in engine/Library/Smarty/sysplugins/smarty_security.php on line 381
Stack trace:
 #0 engine/Library/Smarty/sysplugins/smarty\_internal\_resource\_file.php(33): Smarty\_Security-\>isTrustedResourceDir('index.tpl') #1 engine/Library/Smarty/sysplugins/smarty\_resource.php(303): Smarty\_Internal\_Resource\_File-\>populate(Object(Smarty\_Template\_Source), NULL) #2 engine/Library/Smarty/sysplugins/smarty\_internal\_resource\_extends.php(41): Smarty\_Resource::source(NULL, Object(Enlight\_Template\_Manager), 'index.tpl') #3 engine/Library/Enlight/Components/Snippet/Resource.php(76): Smarty\_Internal\_Resource\_Extends-\>populate(Object(Smarty\_Template\_Source), Object(Enlight\_Template\_Default)) #4 engine/Library/Smarty/sysplugins/smarty\_resource.php(303): Enlight\_Components\_Snippet\_Resource-\>populate(Object(Smarty\_Template\_Source), Object(Enlight\_Template\_Default)) #5 engine/Library/Smarty/sysplugins/smarty\_internal\_template.php(636): Smarty\_Resource::source(Object(Enlight\_Template\_Default)) #6 engine/Library/Smarty/sysplugins/smarty\_cacheresource.php(289): Smarty\_Internal\_Template-\>\_\_get('source') #7 engine/Library/Smarty/sysplugins/smarty\_internal\_template.php(661): Smarty\_Template\_Cached-\>\_\_construct(Object(Enlight\_Template\_Default)) #8 engine/Library/Smarty/sysplugins/smarty\_internal\_templatebase.php(398): Smarty\_Internal\_Template-\>\_\_get('cached') #9 engine/Shopware/Controllers/Backend/Newsletter.php(418): Smarty\_Internal\_TemplateBase-\>isCached(Object(Enlight\_Template\_Default)) #10 engine/Shopware/Controllers/Backend/Newsletter.php(212): Shopware\_Controllers\_Backend\_Newsletter-\>initTemplate(Array) #11 var/cache/production\_201804030942/proxies/ShopwareControllersBackendNewsletterProxy.php(7): Shopware\_Controllers\_Backend\_Newsletter-\>mailAction() #12 engine/Library/Enlight/Hook/HookManager.php(186): Shopware\_Proxies\_ShopwareControllersBackendNewsletterProxy-\>executeParent('mailAction', Array) #13 var/cache/production\_201804030942/proxies/ShopwareControllersBackendNewsletterProxy.php(23): Enlight\_Hook\_HookManager-\>executeHooks(Object(Shopware\_Proxies\_ShopwareControllersBackendNewsletterProxy), 'mailAction', Object(Enlight\_Hook\_HookArgs)) #14 engine/Shopware/Controllers/Backend/Newsletter.php(309): Shopware\_Proxies\_ShopwareControllersBackendNewsletterProxy-\>mailAction() #15 engine/Library/Enlight/Controller/Action.php(193): Shopware\_Controllers\_Backend\_Newsletter-\>cronAction() #16 engine/Library/Enlight/Controller/Dispatcher/Default.php(549): Enlight\_Controller\_Action-\>dispatch('cronAction') #17 engine/Library/Enlight/Controller/Front.php(222): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #18 engine/Shopware/Kernel.php(215): Enlight\_Controller\_Front-\>dispatch() #19 vendor/symfony/http-kernel/HttpCache/HttpCache.php(486): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #20 engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #21 vendor/symfony/http-kernel/HttpCache/HttpCache.php(253): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #22 engine/Shopware/Components/HttpCache/AppCache.php(105): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #23 shopware.php(122): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #24 {main}
Auch bei der Vorschau kommt diese Meldung. Wir verwenden ein eigenes Theme. Damit dieses als Fehlerquelle ausgeschlossen werden konnte haben wir auch auf das Standardtheme umgestellt. Leider ohne Erfolg. Cache wurde auch immer wieder geleert. Vielen Dank im Voraus für Eure Antworten. morpheus1975
