ich stehe mit dem Newsletter eh auf Kriegsfuß. Drum habe ich lange keine verschickt. Nun soll einer rausgehen, ist soweit fertig und ich will eine Testmail versenden. Hier kommt es zur folgenden Fehlermeldung (beim Vorschaubutton ebenfalls):
Syntax Error in template "/var/www/vhosts/domain.de/verzeichnis/themes/Frontend/verzeichnis/newsletter/index/footer.tpl" on line 93 "<a href="{$sStart|dirname}/backend/newsletter?campaign={$sCampaign.id}&mailaddress={$sUser.mailaddressID}&hash={$sCampaignHash}" target="_blank" style="color:#000 !important;">" modifier 'dirname' not allowed by security setting in engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php on line 657
Stack trace:
#0 engine/Library/Smarty/sysplugins/smarty_security.php(227): Smarty_Internal_TemplateCompilerBase->trigger_template_error('modifier 'dirna...')
#1 engine/Library/Smarty/sysplugins/smarty_internal_compile_private_modifier.php(98): Smarty_Security->isTrustedPhpModifier('dirname', Object(Smarty_Internal_SmartyTemplateCompiler))
#2 engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(475): Smarty_Internal_Compile_Private_Modifier->compile(Array, Object(Smarty_Internal_SmartyTemplateCompiler), Array, NULL, NULL)
#3 engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(249): Smarty_Internal_TemplateCompilerBase->callTagCompiler('private_modifie...', Array, Array)
#4 engine/Library/Smarty/sysplugins/smarty_internal_compile_private_print_expression.php(65): Smarty_Internal_TemplateCompilerBase->compileTag('private_modifie...', Array, Array)
#5 engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(475): Smarty_Internal_Compile_Private_Print_Expression->compile(Array, Object(Smarty_Internal_SmartyTemplateCompiler), Array, NULL, NULL)
#6 engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(249): Smarty_Internal_TemplateCompilerBase->callTagCompiler('private_print_e...', Array, Array)
#7 engine/Library/Smarty/sysplugins/smarty_internal_templateparser.php(2358): Smarty_Internal_TemplateCompilerBase->compileTag('private_print_e...', Array, Array)
#8 engine/Library/Smarty/sysplugins/smarty_internal_templateparser.php(3101): Smarty_Internal_Templateparser->yy_r28()
#9 engine/Library/Smarty/sysplugins/smarty_internal_templateparser.php(3201): Smarty_Internal_Templateparser->yy_reduce(28)
#10 engine/Library/Smarty/sysplugins/smarty_internal_smartytemplatecompiler.php(105): Smarty_Internal_Templateparser->doParse(10, '/backend/newsle...')
#11 engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(192): Smarty_Internal_SmartyTemplateCompiler->doCompile('
{s name='NewsletterFooterLinkNewWindow'}{/s}
Ich such schonmal…
