Hallo
Ich möchte eine Testmail raussenden allerdings bekomme ich folgenden Fehler:
Syntax Error in template „d5ad58746920195339f177eb16a322c69be83500“ on line 3 „<p><br /> <!–[if mso]><br /> <style type=‚text/css‘><br /> .primary-font {<br /> font-family: Arial, sans-serif !important;<br /> }<br /> </style><br /> <![endif]–></p>“ - Unexpected "
Stack trace:
#0 Smarty/sysplugins/smarty\_internal\_templateparser.php(3144): Smarty\_Internal\_TemplateCompilerBase-\>trigger\_template\_error() #1 Smarty/sysplugins/smarty\_internal\_templateparser.php(3209): Smarty\_Internal\_Templateparser-\>yy\_syntax\_error(69, 'doParse(69, 'doCompile('
\<!DOCTYPE...') #4 Smarty/sysplugins/smarty\_internal\_template.php(187): Smarty\_Internal\_TemplateCompilerBase-\>compileTemplate(Object(Enlight\_Template\_Default)) #5 Smarty/sysplugins/smarty\_internal\_templatebase.php(155): Smarty\_Internal\_Template-\>compileTemplateSource() #6 Smarty/sysplugins/smarty\_internal\_template.php(286): Smarty\_Internal\_TemplateBase-\>fetch(NULL, NULL, NULL, NULL, false, false, true) #7 var/cache/production\_201605230943/templates/frontend\_Houseofprotein\_de\_DE\_1/22/f6/d9/22f6d9387938171ccf0f1e52f8f428ba2046c6e9.snippet.text.tpl.php(36): Smarty\_Internal\_Template-\>getSubTemplate('string:
\<!...', NULL, 'frontend\_Houseo...', NULL, NULL, Array, 0) #8 Smarty/sysplugins/smarty\_internal\_templatebase.php(180): content\_587b8103ba9391\_62470185(Object(Enlight\_Template\_Default)) #9 Smarty/sysplugins/smarty\_internal\_template.php(286): Smarty\_Internal\_TemplateBase-\>fetch(NULL, NULL, NULL, NULL, false, false, true) #10 var/cache/production\_201605230943/templates/frontend\_Houseofprotein\_de\_DE\_1/b5/45/7d/b5457d24abb5c004cc9b3d2adf2b3d650145404f.snippet.index.tpl.php(83): Smarty\_Internal\_Template-\>getSubTemplate('newsletter/cont...', NULL, 'frontend\_Houseo...', 0, NULL, Array, 0) #11 Smarty/sysplugins/smarty\_internal\_templatebase.php(180): content\_587b8103b6c4b7\_63293127(Object(Enlight\_Template\_Default)) #12 Shopware/Controllers/Backend/Newsletter.php(100): Smarty\_Internal\_TemplateBase-\>fetch('newsletter/inde...', Object(Enlight\_Template\_Manager)) #13 Enlight/Controller/Action.php(158): Shopware\_Controllers\_Backend\_Newsletter-\>viewAction() #14 Enlight/Controller/Dispatcher/Default.php(523): Enlight\_Controller\_Action-\>dispatch('viewAction') #15 Enlight/Controller/Front.php(226): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #16 Shopware/Kernel.php(153): Enlight\_Controller\_Front-\>dispatch() #17 vendor/symfony/http-kernel/HttpCache/HttpCache.php(492): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #18 Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #19 vendor/symfony/http-kernel/HttpCache/HttpCache.php(263): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #20 Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #21 shopware.php(101): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #22 {main}
Habe einen HTML Code dafür getippt allerdings weiß ich nicht warum er die Mail nicht sendet.
