Hallo liebe Community,
nach einem Update von 5.6.2 auf 5.6.7 erscheint in unserem Shop folgende Fehlermeldung:
Slim Application Error
Type: Exception
Message: Parent Stratus of theme Shop not found
File: /var/www/vhosts/ultraguenstig.com/httpdocs/engine/Shopware/Components/Theme/Installer.php
Line: 370
Trace
#0 /var/www/vhosts/ultraguenstig.com/httpdocs/engine/Shopware/Components/Theme/Installer.php(152): Shopware\Components\Theme\Installer->setParents(Array)
#1 /var/www/vhosts/ultraguenstig.com/httpdocs/engine/Shopware/Components/Theme/Installer.php(117): Shopware\Components\Theme\Installer->synchronizeThemes()
#2 /var/www/vhosts/ultraguenstig.com/httpdocs/recovery/update/src/app.php(170): Shopware\Components\Theme\Installer->synchronize()
#3 [internal function]: {closure}()
#4 /var/www/vhosts/ultraguenstig.com/httpdocs/recovery/common/vendor/slim/slim/Slim/Route.php(468): call_user_func_array(Object(Closure), Array)
#5 /var/www/vhosts/ultraguenstig.com/httpdocs/recovery/common/vendor/slim/slim/Slim/Slim.php(1355): Slim\Route->dispatch()
#6 /var/www/vhosts/ultraguenstig.com/httpdocs/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()
#7 /var/www/vhosts/ultraguenstig.com/httpdocs/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()
#8 /var/www/vhosts/ultraguenstig.com/httpdocs/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()
#9 /var/www/vhosts/ultraguenstig.com/httpdocs/recovery/common/vendor/slim/slim/Slim/Slim.php(1300): Slim\Middleware\PrettyExceptions->call()
#10 /var/www/vhosts/ultraguenstig.com/httpdocs/recovery/update/index.php(57): Slim\Slim->run()
#11 {main}
Wenn Sie uns diesbezüglich helfen könnten, wären wir Ihnen sehr verbunden.
Mit besten Grüßen,
Daniel Keller
