Fehlemeldung beim Update auf 5.4.1
beim Update auf unserem Testserver von 5.4.0 auf 5.4.1 kommt beim Aufräumen folgende Fehlermeldung. Was ist das ?
Danke
Peter
Slim Application Error
Type: Exception
Message: Parent CleanTheme of theme Artstore not found
File: /var/www/clients/client984/web2330/web/testserver/engine/Shopware/Components/Theme/Installer.php
Line: 390
Trace
#0 /var/www/clients/client984/web2330/web/testserver/engine/Shopware/Components/Theme/Installer.php(165): Shopware\Components\Theme\Installer->setParents(Array)
#1 /var/www/clients/client984/web2330/web/testserver/engine/Shopware/Components/Theme/Installer.php(130): Shopware\Components\Theme\Installer->synchronizeThemes()
#2 /var/www/clients/client984/web2330/web/testserver/recovery/update/src/app.php(170): Shopware\Components\Theme\Installer->synchronize()
#3 [internal function]: {closure}()
#4 /var/www/clients/client984/web2330/web/testserver/recovery/common/vendor/slim/slim/Slim/Route.php(462): call_user_func_array(Object(Closure), Array)
#5 /var/www/clients/client984/web2330/web/testserver/recovery/common/vendor/slim/slim/Slim/Slim.php(1326): Slim\Route->dispatch()
#6 /var/www/clients/client984/web2330/web/testserver/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()
#7 /var/www/clients/client984/web2330/web/testserver/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()
#8 /var/www/clients/client984/web2330/web/testserver/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()
#9 /var/www/clients/client984/web2330/web/testserver/recovery/common/vendor/slim/slim/Slim/Slim.php(1271): Slim\Middleware\PrettyExceptions->call()
#10 /var/www/clients/client984/web2330/web/testserver/recovery/update/index.php(69): Slim\Slim->run()
#11 {main}
das klingt, als wäre ein Theme bei dir aktiv, wo Verknüpfungen bzw. das Eltern-Template fehlt. - Laut Meldung.
Schau mal ob du bei den Shops/Subshops so ein Theme gewählt hast. Man könnte das dann umgehen, in dem man vor dem Update auf das Standard-Theme wechselt. Das könnte man zumindest probieren, um dort weiterzukommen.
Sebastian
