Dort bekomme ich diese Fehlermeldung: An exception occurred while executing ‚SELECT s0_.id AS id0, s0_.main_detail_id AS main_detail_id1, s0_.supplierID AS supplierID2, s0_.taxID AS taxID3, s0_.pricegroupID AS pricegroupID4, s0_.filtergroupID AS filtergroupID5, s0_.configurator_set_id AS configurator_set_id6, s0_.name AS name7, s0_.description AS description8, s0_.description_long AS description_long9, s0_.datum AS datum10, s0_.active AS active11, s0_.pseudosales AS pseudosales12, s0_.topseller AS topseller13, s0_.keywords AS keywords14, s0_.metaTitle AS metaTitle15, s0_.changetime AS changetime16, s0_.pricegroupActive AS pricegroupActive17, s0_.laststock AS laststock18, s0_.crossbundlelook AS crossbundlelook19, s0_.notification AS notification20, s0_.template AS template21, s0_.mode AS mode22, s0_.available_from AS available_from23, s0_.available_to AS available_to24, s1_.id AS id25, s1_.articleID AS articleID26, s1_.unitID AS unitID27, s1_.ordernumber AS ordernumber28, s1_.suppliernumber AS suppliernumber29, s1_.kind AS kind30, s1_.additionaltext AS additionaltext31, s1_.active AS active32, s1_.instock AS instock33, s1_.stockmin AS stockmin34, s1_.weight AS weight35, s1_.width AS width36, s1_.length AS length37, s1_.height AS height38, s1_.ean AS ean39, s1_.position AS position40, s1_.minpurchase AS minpurchase41, s1_.purchasesteps AS purchasesteps42, s1_.maxpurchase AS maxpurchase43, s1_.purchaseunit AS purchaseunit44, s1_.referenceunit AS referenceunit45, s1_.packunit AS packunit46, s1_.shippingfree AS shippingfree47, s1_.releasedate AS releasedate48, s1_.shippingtime AS shippingtime49, s2_.id AS id50, s2_.tax AS tax51, s2_.description AS description52, s3_.id AS id53, s3_.articleID AS articleID54, s3_.articledetailsID AS articledetailsID55, s3_.attr1 AS attr156, s3_.attr2 AS attr257, s3_.attr3 AS attr358, s3_.attr4 AS attr459, s3_.attr5 AS attr560, s3_.attr6 AS attr661, s3_.attr7 AS attr762, s3_.attr8 AS attr863, s3_.attr9 AS attr964, s3_.attr10 AS attr1065, s3_.attr11 AS attr1166, s3_.attr12 AS attr1267, s3_.attr13 AS attr1368, s3_.attr14 AS attr1469, s3_.attr15 AS attr1570, s3_.attr16 AS attr1671, s3_.attr17 AS attr1772, s3_.attr18 AS attr1873, s3_.attr19 AS attr1974, s3_.attr20 AS attr2075 FROM s_articles s0_ LEFT JOIN s_articles_details s1_ ON s0_.main_detail_id = s1_.id LEFT JOIN s_core_tax s2_ ON s0_.taxID = s2_.id LEFT JOIN WHERE s0_.id = ?‘ with params [„557“]: SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‚WHERE s0_.id = ‚557‘‘ at line 1 in vendor/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php on line 91 Stack trace: #0 vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(701): Doctrine\DBAL\DBALException::driverExceptionDuringQuery(Object(PDOException), ‚SELECT s0_.id A…‘, Array) #1 vendor/doctrine/orm/lib/Doctrine/ORM/Query/Exec/SingleSelectExecutor.php(50): Doctrine\DBAL\Connection->executeQuery(‚SELECT s0_.id A…‘, Array, Array, NULL) #2 vendor/doctrine/orm/lib/Doctrine/ORM/Query.php(286): Doctrine\ORM\Query\Exec\SingleSelectExecutor->execute(Object(Doctrine\DBAL\Connection), Array, Array) #3 vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(794): Doctrine\ORM\Query->_doExecute() #4 vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(586): Doctrine\ORM\AbstractQuery->execute(NULL, 2) #5 Shopware/Controllers/Backend/Article.php(1713): Doctrine\ORM\AbstractQuery->getArrayResult() #6 Shopware/Controllers/Backend/Article.php(2011): Shopware_Controllers_Backend_Article->getArticleData(‚557‘) #7 Shopware/Controllers/Backend/Article.php(1484): Shopware_Controllers_Backend_Article->getArticle(‚557‘) #8 Enlight/Controller/Action.php(159): Shopware_Controllers_Backend_Article->loadStoresAction() #9 Enlight/Controller/Dispatcher/Default.php(528): Enlight_Controller_Action->dispatch(‚loadStoresActio…‘) #10 Enlight/Controller/Front.php(228): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #11 Shopware/Kernel.php(145): Enlight_Controller_Front->dispatch() #12 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(471): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #13 Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #14 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(242): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #15 Shopware/Components/HttpCache/AppCache.php(102): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true) #16 shopware.php(109): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #17 {main}
