habe einfach nur den Cache gelöscht danach kam folgende Fehlermeldung. Ups! Ein Fehler ist aufgetreten! Die nachfolgenden Hinweise sollten Ihnen weiterhelfen. Unknown number format type ‘boolean’. Format ‘’ must be a valid number format string. in Vendor/Zend/library/Zend/Locale/Format.php on line 102 Stack trace: #0 Vendor/Zend/library/Zend/Locale/Format.php(305): Zend_Locale_Format::_checkOptions(Array) #1 Vendor/Zend/library/Zend/Currency.php(186): Zend_Locale_Format::toNumber(0, Array) #2 Enlight/Template/Plugins/modifier.currency.php(41): Zend_Currency->toCurrency(0, Array) #3 cache/templates/templates_tutorial_de_DE_1^604ff776e98aebfaf69dd2ecc1dec78f881f7f26.extends.index.tpl.php(873): smarty_modifier_currency(0) #4 Vendor/Smarty/libs/sysplugins/smarty_internal_template.php(436): include(’/homepages/27/d…’) #5 Enlight/Template/Template.php(46): Smarty_Internal_Template->renderTemplate() #6 Vendor/Smarty/libs/sysplugins/smarty_internal_template.php(568): Enlight_Template_Template->renderTemplate() #7 Vendor/Smarty/libs/Smarty.class.php(328): Smarty_Internal_Template->getRenderedTemplate() #8 Vendor/Smarty/libs/sysplugins/smarty_internal_template.php(865): Smarty->fetch(Object(Enlight_Template_Template)) #9 Enlight/View/ViewDefault.php(153): Smarty_Internal_Template->fetch() #10 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(87): Enlight_View_ViewDefault->render(Object(Enlight_Template_Template)) #11 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(102): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->renderTemplate(Object(Enlight_Template_Template)) #12 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(43): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->render() #13 Enlight/Event/EventHandler.php(60): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->onPostDispatch(Object(Enlight_Event_EventArgs)) #14 Enlight/Event/EventManager.php(70): Enlight_Event_EventHandler->execute(Array, Object(Enlight_Event_EventArgs)) #15 Enlight/Controller/Action.php(76): Enlight_Event_EventManager->notify(Object(Enlight_Event_EventArgs)) #16 Enlight/Controller/Dispatcher/DispatcherDefault.php(329): Enlight_Controller_Action->dispatch(‘Enlight_Control…’, Array) #17 Enlight/Controller/Front.php(99): Enlight_Controller_Dispatcher_DispatcherDefault->dispatch(‘indexAction’) #18 Shopware/Bootstrap.php(33): Enlight_Controller_Front->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #19 Enlight/Application.php(86): Shopware_Bootstrap->run() #20 shopware.php(6): Enlight_Application->run() #21 {main}
