Migration 5.5x ==> 6.0.0 läuft ohne Fehler durch: only Warnings in swag_migration_logging
Ich habe in der swag_migration_logging Tabelle Warnings entdeckt:
-- Daten für Tabelle `swag_migration_logging`
INSERT INTO `swag_migration_logging` (`id`, `run_id`, `type`, `log_entry`, `created_at`, `updated_at`) VALUES
(0x0e1096ebae3e485587b993f44ae79280, 0xf7de6952f21a4462884466788368fe6f, 'warning', '{\"code\":\"SWAG_MIGRATION__SHOPWARE_NOT_CONVERT_ABLE_OBJECT_TYPE\",\"title\":\"Not convert able object type\",\"description\":\"Translation of object type \\\"custom_facet\\\" could not be converted.\",\"details\":{\"objectType\":\"custom_facet\",\"data\":{\"id\":\"3\",\"objecttype\":\"custom_facet\",\"objectdata\":\"a:1:{i:0;a:1:{s:5:\\\"label\\\";s:9:\\\"Varianten\\\";}}\",\"objectkey\":\"1\",\"objectlanguage\":\"1\",\"dirty\":\"0\",\"locale\":\"de-CH\",\"name\":null},\"count\":0}}', '2019-08-01 18:00:23.971', NULL),
(0x68ceaced512949ba9caf3ef91327730d, 0xf7de6952f21a4462884466788368fe6f, 'warning', '{\"code\":\"SWAG_MIGRATION__SHOPWARE_EMPTY_NECESSARY_DATA_FIELDS\",\"title\":\"Unsupported number range type\",\"description\":\"NumberRange-Entity could not be converted because of unsupported type: sSERVICE1.\",\"details\":{\"id\":\"926\",\"entity\":\"NumberRange\",\"count\":1}}', '2019-08-01 18:00:18.622', NULL),
(0xab9900a79b4746328dd338fee795ea77, 0xf7de6952f21a4462884466788368fe6f, 'warning', '{\"code\":\"SWAG_MIGRATION__SHOPWARE_EMPTY_NECESSARY_DATA_FIELDS\",\"title\":\"Unsupported number range type\",\"description\":\"NumberRange-Entity could not be converted because of unsupported type: blogordernumber.\",\"details\":{\"id\":\"928\",\"entity\":\"NumberRange\",\"count\":1}}', '2019-08-01 18:00:18.623', NULL),
(0xad613ff5e43848068ff31e26aa85a700, 0xf7de6952f21a4462884466788368fe6f, 'warning', '{\"code\":\"SWAG_MIGRATION__SHOPWARE_EMPTY_NECESSARY_DATA_FIELDS\",\"title\":\"Empty necessary data\",\"description\":\"NumberRange-Entity could not be converted cause of empty necessary field(s): typeId.\",\"details\":{\"id\":\"924\",\"entity\":\"NumberRange\",\"fields\":[\"typeId\"],\"count\":1}}', '2019-08-01 18:00:18.621', NULL),
(0xb98e39146d914824ae9c978d879b0fe3, 0xf7de6952f21a4462884466788368fe6f, 'warning', '{\"code\":\"SWAG_MIGRATION__SHOPWARE_EMPTY_NECESSARY_DATA_FIELDS\",\"title\":\"Unsupported number range type\",\"description\":\"NumberRange-Entity could not be converted because of unsupported type: sSERVICE2.\",\"details\":{\"id\":\"927\",\"entity\":\"NumberRange\",\"count\":1}}', '2019-08-01 18:00:18.622', NULL);
Wie finde ich nun heraus welche Daten (aus dem 5.5.x Shop neheme ich an), das verursachen?
Resp. muss ich mich um diese Warnings gar nicht kümmern?
Version 5: 5.5.8
Connector: 0.10.2
Version 6: 6.0.0-ea1
Migr. Assistent: 0.10.2
Die Warnings oben betreffen eine Übersetzung im Bereich der Filter (wird eh nicht migriert) und mehrere Nummernkreise. Wahrscheinlich hast du Nummernkreise im System, die es in einer Standardinstallation nicht gibt. Vielleicht kannst du ja mal einen Screenshot aus den Grundeinstellungen > Nummernkreise hier rein packen.
Ansonsten ist das aber unkritisch.
Hier der Screenshot aus den Grundeinstellungen des 5er shop (migrations source):
Habe die Service - 1 / Service - 2 / Blog - ID gelöscht (im SW5) und siehe da, die Fehlermeldungen der Nummernkreise ist weg.
Danke für die Info.
