Migration Bestellungen Shopware 5 auf 6
Moin,
Da der Goldstatus als Subskription scheinbar für einen vernünftigen Support von Shopware selbst nicht ausreicht, soll ich hier mal nachfragen…
Ich weiß nicht ob es mit so vielen Problemen und nicht vollständiger Doku sinnvoll ist auf Shopware 6 umzustellen, aber gut, mein Problem ist, das ich von 119895 Bestellungen lediglich nur 10589 migriert bekomme.
Im Migrationlog sind mir folgende Fehler aufgefallen:
[info] SWAG_MIGRATION_LANGUAGE_ENTITY_ALREADY_EXISTS
The language entity already exists
The language entity with source id "1" already exists and cannot be written.
[info] SWAG_MIGRATION__SHOPWARE_UNSUPPORTED_NUMBER_RANGE_TYPE
Unsupported number range type
NumberRange-Entity with source id "926" could not be converted because of unsupported type: sSERVICE1.
NumberRange-Entity with source id "927" could not be converted because of unsupported type: sSERVICE2.
NumberRange-Entity with source id "937" could not be converted because of unsupported type: doc_2_4.
NumberRange-Entity with source id "936" could not be converted because of unsupported type: doc_1_4.
NumberRange-Entity with source id "935" could not be converted because of unsupported type: doc_0_4.
NumberRange-Entity with source id "934" could not be converted because of unsupported type: doc_2_2.
NumberRange-Entity with source id "933" could not be converted because of unsupported type: doc_1_2.
NumberRange-Entity with source id "932" could not be converted because of unsupported type: doc_0_2.
NumberRange-Entity with source id "931" could not be converted because of unsupported type: doc_2_.
NumberRange-Entity with source id "930" could not be converted because of unsupported type: doc_1_.
NumberRange-Entity with source id "929" could not be converted because of unsupported type: doc_0_.
NumberRange-Entity with source id "928" could not be converted because of unsupported type: blogordernumber.
Dann gehts weiter mit:
[warning] SWAG_MIGRATION_EMPTY_NECESSARY_FIELD_CUSTOMER
The customer entity has one or more empty necessary fields
The customer entity with the source id 49 does not have the necessary data for the field(s): firstname
usw .....
The customer entity with the source id 12972 does not have the necessary data for the field(s): address data
The customer entity with the source id 13030 does not have the necessary data for the field(s): firstname
[warning] SWAG_MIGRATION_EMPTY_NECESSARY_FIELD_CUSTOMER_ADDRESS
The customer_address entity has one or more empty necessary fields
The customer_address entity with the source id 12954 does not have the necessary data for the field(s): city
[warning] SWAG_MIGRATION_EMPTY_NECESSARY_FIELD_ORDER
The order entity has one or more empty necessary fields
The order entity with the source id 81620 does not have the necessary data for the field(s): customer
The order entity with the source id 101920 does not have the necessary data for the field(s): customer,payment
Wie finde ich raus, was er nun für ein Problem hat?
Es gibt scheinbar viele Fehler. Zum Beispiel fehlen bei einigen Kunden in Shopware 5 Pflichtfelder wie Adresse, Stadt, Vorname, etc.
Zudem wurden Kunden und Zahlungsarten gelöscht, die sind aber in SW 5 noch bei Bestellungen hinterlegt.
Erster Schritt wäre grundlegende Dinge in der SW5-Datenbank zu prüfen und zu bereinigen und dann noch einmal neu migrieren. Vieles dürften dann Folgefehler (gewesen) sein, da z.b. Bestellungen ohne Kunden nicht migriert werden können.
Unter folgendem Link haben wir einen kostenlosen Leitfaden, der viele (auch technische) Themen behandelt: Shopware 6 Migration ✓ Ultimativer Leitfaden ✓ Checkliste
Zu Bedenken ist aber: Shopware 6 ist (technisch) deutlich komplexer als Shopware 5. Das gleiche gilt ebenso für die Migration. Ohne erweitertes technisches Wissen und Erfahrung mit Shopware 5 und 6 wird es schwierig. Das betrifft die saubere Einrichtung von Shopware 6, die Migration, aber auch spätere Wartung/Updates.
