Lokale Kopie
Ich habe mir eine lokale Kopie angelegt: Ubuntu und PHP7.2
Das Problem ist, dass ich nach der Eingabe der persönlichen Daten einen fatalen Fehler erhalte.
Kann mir da vielleicht jemand einen Tipp geben, wie ich das fixen kann?
Fatal error : Uncaught Error: Class ‘Symfony\Component\Intl\DateFormatter\DateFormat\TimezoneTransformer’ not found in /var/www/html/vendor/symfony/intl/DateFormatter/DateFormat/FullTransformer.php:68
Stack trace:
#0 /var/www/html/vendor/symfony/intl/DateFormatter/IntlDateFormatter.php(214): Symfony\Component\Intl\DateFormatter\DateFormat\FullTransformer->__construct(‘y’, ‘Europe/Berlin’)
#1 /var/www/html/vendor/symfony/form/Extension/Core/Type/DateType.php(297): Symfony\Component\Intl\DateFormatter\IntlDateFormatter->format(-2257804800)
#2 /var/www/html/vendor/symfony/form/Extension/Core/Type/DateType.php(99): Symfony\Component\Form\Extension\Core\Type\DateType->formatTimestamps(Object(IntlDateFormatter), ‘/y+/’, Array)
#3 /var/www/html/vendor/symfony/form/ResolvedFormType.php(126): Symfony\Component\Form\Extension\Core\Type\DateType->buildForm(Object(Symfony\Component\Form\FormBuilder), Array)
#4 /var/www/html/vendor/symfony/form/ResolvedFormType.php(123): Symfony\Component\Form\ResolvedFormType->buildForm(Object(Symfony\Component\Form\FormBuilder), Array)
#5 /var/www/html/vendor/symfony/form/FormFactory.php(80): Symfony\Component\Form\ResolvedFormType->buildForm(Object(Symfony\Component\Form\FormBuilder), Array)
#6 /var/www/html/vendor/symfony/form/FormBuilder.php(106): Symfony\Component\Form\FormFactory->createNamedBuilder(‘birthday’, Object(Symfony\Component\Form\ResolvedFormType), NULL, Array)
#7 /var/www/html/vendor/symfony/form/FormBuilder.php(269): Symfony\Component\Form\FormBuilder->create(‘birthday’, ‘Symfony\Compone…’, Array)
#8 /var/www/html/vendor/symfony/form/FormBuilder.php(215): Symfony\Component\Form\FormBuilder->resolveChildren()
#9 /var/www/html/vendor/symfony/form/FormFactory.php(30): Symfony\Component\Form\FormBuilder->getForm()
#10 /var/www/html/engine/Library/Enlight/Controller/Action.php(440): Symfony\Component\Form\FormFactory->creat in /var/www/html/vendor/symfony/intl/DateFormatter/DateFormat/FullTransformer.php on line 68
Kling irgendwie danach, dass du Probleme mit den date columns in der Datenbank hast. Vielleicht sind die beim Import kaputt gegangen.
Ääähm… na klar doch!
Nein, verrate mir bitte, welche Tabelle. Ein Kollege hat genau das gleiche Problem. Bei ihm eine virtuelle Maschine unter Windows.
Ich habe eben noch einmal einen aktuellen Dump in meine lokale Datenbank eingelesen, Jetzt funktioniert es.
