Nach unserem Umzug zu einem neuen Provider kann ich die Duplizieren Schaltfläche nichtmehr nutzen, keine Belege (wegen inkonsistenten Daten) erstellen und auch keine Varianten-Artikel anlegen.
Artikel auf normalem Wegen neu Anlegen funktioniert jedoch.
Ich habe in meinem Log folgende Fehlermeldungen nach Versuch die Duplizieren-Schaltfläche zu nutzen.
[2018-08-25 06:10:53] core.CRITICAL: DateTime::__construct(): Failed to parse time string (NULL) at position 0 (N): The timezone could not be found in the database {“uid”:“d7937a7”}
[2018-08-25 06:10:53] core.ERROR: exception ‘Exception’ with message ‘DateTime::__construct(): Failed to parse time string (NULL) at position 0 (N): The timezone could not be found in the database’ in /var/www/clients/client3861/web7811/web/var/cache/production_201712131442/doctrine/attributes/Customer.php:138 Stack trace: #0 /var/www/clients/client3861/web7811/web/var/cache/production_201712131442/doctrine/attributes/Customer.php(138): DateTime->__construct(‘NULL’) #1 /var/www/clients/client3861/web7811/web/vendor/symfony/form/Extension/Core/Type/FormType.php(136): Shopware\Models\Attribute\Customer->__construct() #2 /var/www/clients/client3861/web7811/web/vendor/symfony/form/Form.php(617): Symfony\Component\Form\Extension\Core\Type\FormType->Symfony\Component\Form\Extension\Core\Type{closure}(Object(Symfony\Component\Form\Form), NULL) #3 /var/www/clients/client3861/web7811/web/vendor/symfony/form/Form.php(577): Symfony\Component\Form\Form->submit(NULL, true) #4 /var/www/clients/client3861/web7811/web/engine/Shopware/Plugins/Community/Frontend/SwagPaymentPaypal/Controllers/Frontend/PaymentPaypal.php(887): Symfony\Component\Form\Form->submit(Array) #5 /var/www/clients/client3861/web7811/web/engine/Shopware/Plugins/Community/Frontend/SwagPaymentPaypal/Controllers/Frontend/PaymentPaypal.php(699): Shopware_Controllers_Frontend_PaymentPaypal->saveUser(Array) #6 /var/www/clients/client3861/web7811/web/engine/Shopware/Plugins/Community/Frontend/SwagPaymentPaypal/Controllers/Frontend/PaymentPaypal.php(319): Shopware_Controllers_Frontend_PaymentPaypal->createAccount(Array) #7 /var/www/clients/client3861/web7811/web/engine/Library/Enlight/Controller/Action.php(159): Shopware_Controllers_Frontend_PaymentPaypal->returnAction() #8 /var/www/clients/client3861/web7811/web/engine/Library/Enlight/Controller/Dispatcher/Default.php(530): Enlight_Controller_Action->dispatch(‘returnAction’) #9 /var/www/clients/client3861/web7811/web/engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #10 /var/www/clients/client3861/web7811/web/engine/Shopware/Kernel.php(191): Enlight_Controller_Front->dispatch() #11 /var/www/clients/client3861/web7811/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(484): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #12 /var/www/clients/client3861/web7811/web/engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #13 /var/www/clients/client3861/web7811/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(441): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #14 /var/www/clients/client3861/web7811/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(337): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true) #15 /var/www/clients/client3861/web7811/web/engine/Shopware/Components/HttpCache/AppCache.php(189): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #16 /var/www/clients/client3861/web7811/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(203): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #17 /var/www/clients/client3861/web7811/web/engine/Shopware/Components/HttpCache/AppCache.php(116): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #18 /var/www/clients/client3861/web7811/web/shopware.php(118): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #19 {main} {“uid”:“d7937a7”}
Kann mir jemand helfen oder hat eine Idee?
