Link in admin menu to plugin configuration
I have a custom module with a new entry in the administration menu. A suboption of that menu should go directly to the plugin options. I expected something like this to work:
routes: {
    config: {
        component: 'sw-plugin-config',
        path: 'settings/:namespace',
        meta: {
            parentPath: 'sw.plugin.index'
        props: {
            namespace: 'MyPlugin',
navigation: [
        label: 'Config',
        path: 'my.plugin.config',
        icon: 'default-object-lab-flask'
This throws the following error: “Encountered an error while loading the configuration:Bundle by name “undefined” not found.”
It does work though when i’m on the plugin page and click the menu option … so it seems there’s some page param that is there on the plugin page that is not there on other pages.
maybe there’s a way to just serve an absolute path? or something
Hi Pascal,
i have the same issue. Have you find out how it works?
Cheers
@Pascal1988 @padaja If you mean the Plugin config which you define in the config xml here you go:
navigation: [
        label: 'Config',
        path: 'sw.plugin.config',
        params: {
                namespace: "MyPluginName"
