Morgen, wo finde ich in der DB die Rechnungs und Lieferscheinnummer? Ich habe leider nur den Counter gefunden. Danke EDIT: Hab was gefunden. s_oder_documents. Steht hier Type 0 für RE und Type 1 für Liefersein?
So, ich möchte nun den Bestellexport anpassen und habe folgenden SQL Code, welcher unter PHPMYADMIN auch funktioniet: $sql = " SELECT `o`.`id`, `o`.`id` as `orderID`, (SELECT docID from s\_order\_documents where $sql\_where and type = 0) as `Rechnung`, (SELECT docID from s\_order\_documents where $sql\_where and type = 1) as `Lieferschein`, `o`.`ordernumber`, `o`.`ordernumber` as `order_number`, `o`.`userID`, `o`.`userID` as `customerID`, `o`.`invoice_amount`, `o`.`invoice_amount_net`, `o`.`invoice_shipping`, `o`.`invoice_shipping_net`, `o`.`ordertime` as `ordertime`, `o`.`status`, `o`.`status` as `statusID`, `o`.`cleared` as `cleared`, `o`.`cleared` as `clearedID`, `o`.`paymentID` as `paymentID`, `o`.`transactionID` as `transactionID`, `o`.`comment`, `o`.`customercomment`, `o`.`net`, `o`.`net` as `netto`, `o`.`partnerID`, `o`.`temporaryID`, `o`.`referer`, o.cleareddate, o.cleareddate as cleared\_date, o.trackingcode, o.language, o.currency, o.currencyFactor, o.subshopID, o.dispatchID, cu.id as currencyID, `c`.`description` as `cleared_description`, `s`.`description` as `status_description`, `p`.`description` as `payment_description`, `d`.`name` as `dispatch_description`, `cu`.`name` as `currency_description` FROM `s_order` as `o` LEFT JOIN `s_core_states` as `s` ON (`o`.`status` = `s`.`id`) LEFT JOIN `s_core_states` as `c` ON (`o`.`cleared` = `c`.`id`) LEFT JOIN `s_core_paymentmeans` as `p` ON (`o`.`paymentID` = `p`.`id`) LEFT JOIN `$dispatch_table` as `d` ON (`o`.`dispatchID` = `d`.`id`) LEFT JOIN `s_core_currencies` as `cu` ON (`o`.`currency` = `cu`.`currency`) $sql\_where "; Diese habe ich in der Shopware.php bei der Methode „sGetOrders“ geändert. Jetzt muss ich bestimmt noch die export.orders.php abändern. So dass ich dann beide neuen Felder in dem Export erhalte. Hat hiermit jmd Erfahrungen?
Mist, Denkfehler. in der $sql_where steht ja status=2, dass kann ich schlecht in der unter SELECT Abfragen. Würde das funktionieren? SELECT `o`.`id`, `o`.`id` as `orderID`, (SELECT docID from s\_order\_documents where orderID = `o`.`id` and type = 0) as `Rechnung`, ... ... EDIT: Mist, schon wieder Denkfehler. So kann es auch nicht gehen
Für jeden Tipp bin ich dankbar.
