Language Pack French - Version Issue
Hello,
I’m currently working in migration from sw5 to sw6. I have the sw6 version 6.5.8.9.
As it is a multilingual shop, I would like to install the French Language Pack from Shopware.
However I have an error message during installation : Error. The extension is not yet available in the current version. Try again later.
It is very strange because, as per the plugin webpage, it should be compatible.
I tried to find an older version of the plugin but cannot find it.
Could you please help ?
Thank you.
Regards
I do not think that a older version will work.
You can log into your Shopware account on https://account.shopware.com, then select your store, the plugin and the version you want to download. If the plugin is not there, you have to „buy“ it first in the Showare store. Also free plugins must be bought.
