Errors while trying to install themes
Sorry, your order could not be proceeded
Free Liberty Responsive Theme Free: Your current shop version is not compatible with this extension. - Error code: BE03
Legendary Theme - Modern & Clean Free: Your current shop version is not compatible with this extension. - Error code: BE03
Free MetroLight Responsive Theme Free: Your current shop version is not compatible with this extension. - Error code: BE03
Flat Responsive Theme Free: Your current shop version is not compatible with this extension. - Error code: BE03
Rome Theme for mpXgastronomy Free: is not compatible with Shopware 5. You can find the compatibility note directly in the article details. - Error code: BE29
Stockholm Theme for mpXgastronomy Free: is not compatible with Shopware 5. You can find the compatibility note directly in the article details. - Error code: BE29
Berlin Theme for mpXgastronomy Free: is not compatible with Shopware 5. You can find the compatibility note directly in the article details. - Error code: BE29
also i get this message
or
You tried to buy/license a Shopware 6 plugin to a registered Shopware 5 domain.
Go to account.shopware.com and create a new Shopware 6 shop with a different domain. Then you can buy the plugin.
it took me a while but solved this problem
Dieses Thema wurde automatisch 30 Tage nach der letzten Antwort geschlossen. Es sind keine neuen Antworten mehr erlaubt.
