Issue with Demoshop
I manage to install Shopware 5 version on Linux Ubuntu (on localhost) and also manage to add and configure payment gateway plugin. So far everything is ok.
The problem is that when I want to make a test purchase from frontend (Demoshop), I am stuck on Address section (see the image attached). When I trying to log in with existing user (created in system), nothing happens when I press the Login button. Also when I am adding new customer via registration form on the right side and press Continue, also nothing happens - it simply reloads the form and it is blank again. I am now stuck with this and unable to move to Payment & shipping section to the page. Can you please advice how this might be fixed?
What is the browser console saying?
When I enter the details and press Login button, the result is like this:
I wondering if anyone has experienced similar behaviour too. There was actually the same outcome when I tried to run everything on Windows10. Just to mention, that I tested several other ecommerce platforms such as Magento, Prestashop, Opencart, Woocommerce successfully.
It looks like a specific problem. You might want to look at this: https://developers.shopware.com/sysadmins-guide/system-requirements/ and this: https://developers.shopware.com/developers-guide/debugging/
Hello Jocky,
it caused actually due to session timeout for the login customer. For localhost the session timeout value is too low, so every time customer login it gets a timeout. for me fix this issue manually set the timeout limit in sAdmin.php  file sCheckUser function. Try this   If the shop is installed in server I won’t get this error.
Thanks @charles0301‍! Manage to fix the problem by changing the relevant sCheckUser code from here:
