interner error 500 nach Installation von shopware 6
Hallo - nach scheinbar erfolgreicher Installation von shopware v6.3.0.1 habe ich am Ende des Install Wizards den Weiter Button, allerdings unmittelbar darauf bekomme ich:
Oops! An Error Occurred
The server returned a „500 Internal Server Error“.
Something is broken. Please let us know what you were doing when this error occurred. We will fix it as soon as possible. Sorry for any inconvenience caused.
in shopware-platform.error.log
[Fri Sep 04 09:22:53.446626 2020] [authz_core:debug] [pid 1743] mod_authz_core.c(820): [client 2.205.35.208:50695] AH01626: authorization result of Require all granted: granted
[Fri Sep 04 09:22:53.447508 2020] [authz_core:debug] [pid 1743] mod_authz_core.c(820): [client 2.205.35.208:50695] AH01626: authorization result of : granted
[Fri Sep 04 09:22:53.447703 2020] [authz_core:debug] [pid 1743] mod_authz_core.c(820): [client 2.205.35.208:50695] AH01626: authorization result of Require all granted: granted
[Fri Sep 04 09:22:53.447765 2020] [authz_core:debug] [pid 1743] mod_authz_core.c(820): [client 2.205.35.208:50695] AH01626: authorization result of : granted
[Fri Sep 04 09:22:53.447888 2020] [alias:debug] [pid 1743] mod_alias.c(683): [client 2.205.35.208:50695] AH00675: incomplete redirection target of ‚/index.php/‘ for URI ‚/‘ modified to ‚http://test521.de/index.php/‘
Es scheint ein Problem mit einen redirect zu sein - wie kann ich das weiter troubleshooten, bzw was kann da falsch sein?
Besten Dank
Update, obwohl der Installer mod_rewrite als grün dargestellt hat, war mod_rewrite nicht geladen, also mod_rewrite für apache enabled, der redirect error ist zwar jetzt weg, allerdings nach wir vor Error 500
[Fri Sep 04 10:32:25.981022 2020] [authz_core:debug] [pid 5451] mod_authz_core.c(820): [client 2.205.35.208:54766] AH01626: authorization result of Require all granted: granted
[Fri Sep 04 10:32:25.981180 2020] [authz_core:debug] [pid 5451] mod_authz_core.c(820): [client 2.205.35.208:54766] AH01626: authorization result of : granted
[Fri Sep 04 10:32:25.981487 2020] [authz_core:debug] [pid 5451] mod_authz_core.c(820): [client 2.205.35.208:54766] AH01626: authorization result of Require all granted: granted
[Fri Sep 04 10:32:25.981499 2020] [authz_core:debug] [pid 5451] mod_authz_core.c(820): [client 2.205.35.208:54766] AH01626: authorization result of : granted
[Fri Sep 04 10:32:26.090764 2020] [authz_core:debug] [pid 5441] mod_authz_core.c(820): [client 2.205.35.208:54765] AH01626: authorization result of Require all granted: granted, referer: http://test521.de/
[Fri Sep 04 10:32:26.090823 2020] [authz_core:debug] [pid 5441] mod_authz_core.c(820): [client 2.205.35.208:54765] AH01626: authorization result of : granted, referer: http://test521.de/
beim versuch das /backend aufzurufen habe ich folgende Einträge (und den Error 500):
[Fri Sep 04 10:42:20.426184 2020] [authz_core:debug] [pid 5441] mod_authz_core.c(820): [client 2.205.35.208:59774] AH01626: authorization result of Require all granted: granted
[Fri Sep 04 10:42:20.426312 2020] [authz_core:debug] [pid 5441] mod_authz_core.c(820): [client 2.205.35.208:59774] AH01626: authorization result of : granted
[Fri Sep 04 10:42:20.426525 2020] [authz_core:debug] [pid 5441] mod_authz_core.c(820): [client 2.205.35.208:59774] AH01626: authorization result of Require all granted: granted
[Fri Sep 04 10:42:20.426533 2020] [authz_core:debug] [pid 5441] mod_authz_core.c(820): [client 2.205.35.208:59774] AH01626: authorization result of : granted
[Fri Sep 04 10:42:57.106170 2020] [authz_core:debug] [pid 5669] mod_authz_core.c(820): [client 2.205.35.208:62231] AH01626: authorization result of Require all granted: granted
[Fri Sep 04 10:42:57.106326 2020] [authz_core:debug] [pid 5669] mod_authz_core.c(820): [client 2.205.35.208:62231] AH01626: authorization result of : granted
[Fri Sep 04 10:42:57.106639 2020] [authz_core:debug] [pid 5669] mod_authz_core.c(820): [client 2.205.35.208:62231] AH01626: authorization result of Require all granted: granted
[Fri Sep 04 10:42:57.106653 2020] [authz_core:debug] [pid 5669] mod_authz_core.c(820): [client 2.205.35.208:62231] AH01626: authorization result of : granted
Hat jemand eine Idee warum shopware nach wie vor Error 500 ausgibt?
Es stellte sich heraus, dass im Table  sales_channel_domain die IP Addresse statt des domain names stand - leider kann man diesen table nicht erfolgreich via phpmyadmin editieren. Zusätzlich ware aus mir unbekannsten Gründen die chache files in shopware mit root ownership angelegt und dadurch nicht beschreibbar.
Was letztlich half war eine komplette Neuinstallation …
