Hallo Zusammen,
ich habe gerade versucht mal ein SW6.5 auf einer unserer Server zu installieren. Ich bekommen es bei keinem Anbieter zum Laufen und habe keine Idee. Es scheitert schon beim Schritt des Herunterladens.
Hat vielleicht jemand eine Idee?
VG Danny
[critical] Error thrown while running command „install -d ‚/usr/www/users/cttkmd/shopware‘ --no-interaction --no-ansi -v“. Message: "Command „install“ is not defined.
Did you mean this?
assets:install"
In Application.php line 702:
[Symfony\Component\Console\Exception\CommandNotFoundException]
Did you mean this?
assets:install
Exception trace:
at phar:///usr/www/users/cttkmd/shopware/shopware-installer.phar.php/vendor/symfony/console/Application.php:702
Symfony\Component\Console\Application->find() at phar:///usr/www/users/cttkmd/shopware/shopware-installer.phar.php/vendor/symfony/framework-bundle/Console/Application.php:105
Symfony\Bundle\FrameworkBundle\Console\Application->find() at phar:///usr/www/users/cttkmd/shopware/shopware-installer.phar.php/vendor/symfony/console/Application.php:256
Symfony\Component\Console\Application->doRun() at phar:///usr/www/users/cttkmd/shopware/shopware-installer.phar.php/vendor/symfony/framework-bundle/Console/Application.php:77
Symfony\Bundle\FrameworkBundle\Console\Application->doRun() at phar:///usr/www/users/cttkmd/shopware/shopware-installer.phar.php/vendor/symfony/console/Application.php:168
Symfony\Component\Console\Application->run() at phar:///usr/www/users/cttkmd/shopware/shopware-installer.phar.php/bin/console:15
require() at /usr/www/users/cttkmd/shopware/shopware-installer.phar.php:41
