Hi.
I set up an SMPT server through the Rackspace Email provider. I think I have everything set up correctly, but it doesn’t work. Do I need to set anything else?
Thank you.
Hi.
Thank you.
Does SMTP work when using a Tester like: https://www.gmass.co/smtp-test ?
Thank you. Through this test, I noticed that the password is not correct ![]()
