Nach der Installation wollte ich das Front- bzw. Backend aufrufen, aber da kommt nur: Warning: require\_once(): Unable to access Zend/Db/Adapter/Pdo/Abstract.php in /var/www/web147/html/shopware/engine/Library/Zend/Db/Adapter/Pdo/Mysql.php on line 27 Warning: require\_once(Zend/Db/Adapter/Pdo/Abstract.php): failed to open stream: No such file or directory in /var/www/web147/html/shopware/engine/Library/Zend/Db/Adapter/Pdo/Mysql.php on line 27 Fatal error: require\_once(): Failed opening required 'Zend/Db/Adapter/Pdo/Abstract.php' (include\_path='.') in /var/www/web147/html/shopware/engine/Library/Zend/Db/Adapter/Pdo/Mysql.php on line 27 Woran kann das liegen?
