Habe heute auf die version 5.2.7 geupdatet, seit dem habe ich nun über 150 Fehlernachrichten per Email erhalten mit folgendem Inhalt:
ERROR
Message: exception 'PDOException' with message 'SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry 'Shopware_CronJob_ShopwareConnectImportImages' for key 'action'' in /www/htdocs/w0144b89/korallenzucht-wolfs.de/vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php:989
Stack trace:
#0 /www/htdocs/w0144b89/korallenzucht-wolfs.de/vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(989): PDOStatement->execute(Array)
#1 /www/htdocs/w0144b89/korallenzucht-wolfs.de/vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(669): Doctrine\DBAL\Connection->executeUpdate('UPDATE s_cronta...', Array, Array)
#2 /www/htdocs/w0144b89/korallenzucht-wolfs.de/engine/Library/Enlight/Components/Cron/Adapter/DBAL.php(77): Doctrine\DBAL\Connection->update('s_crontab', Array, Array)
#3 /www/htdocs/w0144b89/korallenzucht-wolfs.de/engine/Library/Enlight/Components/Cron/Manager.php(124): Enlight_Components_Cron_Adapter_DBAL->updateJob(Object(Enlight_Components_Cron_Job))
#4 /www/htdocs/w0144b89/korallenzucht-wolfs.de/engine/Library/Enlight/Components/Cron/Manager.php(269): Enlight_Components_Cron_Manager->disableJob(Object(Enlight_Components_Cron_Job))
#5 /www/htdocs/w0144b89/korallenzucht-wolfs.de/engine/Shopware/Plugins/Default/Core/Cron/Cron.php(52): Enlight_Components_Cron_Manager->runJob(Object(Enlight_Components_Cron_Job))
#6 /www/htdocs/w0144b89/korallenzucht-wolfs.de/engine/Library/Enlight/Controller/Action.php(159): Shopware_Controllers_Backend_Cron->indexAction()
#7 /www/htdocs/w0144b89/korallenzucht-wolfs.de/engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch('indexAction')
#8 /www/htdocs/w0144b89/korallenzucht-wolfs.de/engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#9 /www/htdocs/w0144b89/korallenzucht-wolfs.de/engine/Shopware/Kernel.php(177): Enlight_Controller_Front->dispatch()
#10 /www/htdocs/w0144b89/korallenzucht-wolfs.de/vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#11 /www/htdocs/w0144b89/korallenzucht-wolfs.de/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#12 /www/htdocs/w0144b89/korallenzucht-wolfs.de/vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#13 /www/htdocs/w0144b89/korallenzucht-wolfs.de/engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)
#14 /www/htdocs/w0144b89/korallenzucht-wolfs.de/shopware.php(113): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#15 {main}
Next exception 'Doctrine\DBAL\DBALException' with message 'An exception occurred while executing 'UPDATE s_crontab SET action = ?, `interval` = ?, data = ?, active = ?, next = ?, start = ?, end = ? WHERE id = ?' with params ["Shopware_CronJob_ShopwareConnectImportImages", 1800, "a:1:{s:5:\"error\";s:441:\"An exception occurred while executing 'UPDATE s_crontab SET action = ?, `interval` = ?, data = ?, active = ?, next = ?, start = ?, end = ? WHERE id = ?' with params [\"Shopware_CronJob_ShopwareConnectImportImages\", 1800, \"b:0;\", \"1\", \"2016-09-09 19:35:42\", \"2016-09-21 20:50:02\", \"2016-09-09 19:35:42\", 23]:\n\nSQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry 'Shopware_CronJob_ShopwareConnectImportImages' for key 'action'\";}", "0", "2016-09-09 19:35:42", "2016-09-21 20:50:02", "2016-09-09 19:35:42", 23]:
SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry 'Shopware_CronJob_ShopwareConnectImportImages' for key 'action'' in /www/htdocs/w0144b89/korallenzucht-wolfs.de/vendor/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php:119
Stack trace:
#0 /www/htdocs/w0144b89/korallenzucht-wolfs.de/vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(996): Doctrine\DBAL\DBALException::driverExceptionDuringQuery(Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(PDOException), 'UPDATE s_cronta...', Array)
#15 {main}
Time: 2016-09-21T20:50:02.905776+0200
Channel: core
request: {
"uri": "/backend/cron",
"method": "GET",
"query": {
"module": "backend",
"controller": "cron",
"action": "index"
"post": []
shop: No shop data available
session: No session data available
Leider sind das für einen Anfänger wie mich zu viele Informationen mit denen ich NIX anfangen kann, ich vermute mal was mit den Cron Jobs?
