Wir haben ein Problem. Wenn man bei uns nach zweistelligen Zahlen z.B. 25 sucht, gibt es eine Fehlermeldung. Bzw. konkret bei eine Kombination wie z.B. „akai mpd 26“ Fatal error: Uncaught exception 'PDOException' with message 'SQLSTATE[HY000]: General error: 2006 MySQL server has gone away' in /home/httpd/shop/engine/Library/Zend/Db/Statement/Pdo.php:228 Stack trace: #0 /home/httpd/shop/engine/Library/Zend/Db/Statement/Pdo.php(228): PDOStatement-\>execute(Array) #1 /home/httpd/shop/engine/Library/Zend/Db/Statement.php(303): Zend\_Db\_Statement\_Pdo-\>\_execute(Array) #2 /home/httpd/shop/engine/Library/Zend/Db/Adapter/Abstract.php(480): Zend\_Db\_Statement-\>execute(Array) #3 /home/httpd/shop/engine/Library/Zend/Db/Adapter/Pdo/Abstract.php(238): Zend\_Db\_Adapter\_Abstract-\>query('SELECT active F...', Array) #4 /home/httpd/shop/engine/Library/Enlight/Components/Db/Adapter/Pdo/Mysql.php(75): Zend\_Db\_Adapter\_Pdo\_Abstract-\>query('SELECT active F...', Array) #5 /home/httpd/shop/engine/Library/Zend/Db/Adapter/Abstract.php(828): Enlight\_Components\_Db\_Adapter\_Pdo\_Mysql-\>query('SELECT active F...', Array) #6 /home/httpd/shop/engine/Shopware/Plugins/Default/Frontend/ in /home/httpd/shop/engine/Library/Zend/Db/Statement/Pdo.php on line 234 503 Service Unavailable Fatal error: Uncaught exception 'PDOException' with message 'SQLSTATE[HY000]: General error: 2006 MySQL server has gone away' in /home/httpd/shop/engine/Library/Zend/Db/Statement/Pdo.php:228 Stack trace: #0 /home/httpd/shop/engine/Library/Zend/Db/Statement/Pdo.php(228): PDOStatement-\>execute(Array) #1 /home/httpd/shop/engine/Library/Zend/Db/Statement.php(303): Zend\_Db\_Statement\_Pdo-\>\_execute(Array) #2 /home/httpd/shop/engine/Library/Zend/Db/Adapter/Abstract.php(480): Zend\_Db\_Statement-\>execute(Array) #3 /home/httpd/shop/engine/Library/Zend/Db/Adapter/Pdo/Abstract.php(238): Zend\_Db\_Adapter\_Abstract-\>query(Object(Zend\_Db\_Table\_Select), Array) #4 /home/httpd/shop/engine/Library/Enlight/Components/Db/Adapter/Pdo/Mysql.php(75): Zend\_Db\_Adapter\_Pdo\_Abstract-\>query(Object(Zend\_Db\_Table\_Select), Array) #5 /home/httpd/shop/engine/Library/Zend/Db/Table/Abstract.php(1575): Enlight\_Components\_Db\_Adapter\_Pdo\_Mysql-\>query(Object(Zend\_Db\_Table\_Select)) #6 /home/httpd/shop/engine/Library/Zend/Db/Ta in /home/httpd/shop/engine/Library/Zend/Db/Statement/Pdo.php on line 234
Ich antworte mal selbst
Hatte max_allowed_packet auf Standard stehen, bzw. angepasst und meine my.cnf wurde wegen zu hoher Zugriffsrechte (777) nicht gelesen und alle Konfigurationen auf Standard gesetzt. Hab jetzt max_allowed_packet auf 16 und alles läuft
