so, bin jetzt bei Sysprovide. Installation läuft durch. Alle Requirements erfüllt.
Es kommt aber am Ende diese Fehlermeldung:
Slim Application Error
Type: ErrorException
Code: 1024
Message: Failed saving metadata to metadataCache
File: /var/www/web4558/html/shopware/engine/Library/Zend/Db/Table/Abstract.php
Line: 839
Trace
#0 [internal function]: Slim\Slim::handleErrors(1024, ‚Failed saving m…‘, ‚/var/www/web455…‘, 839, Array)
#1 /var/www/web4558/html/shopware/engine/Library/Zend/Db/Table/Abstract.php(839): trigger_error(‚Failed saving m…‘, 1024)
#2 /var/www/web4558/html/shopware/engine/Library/Zend/Db/Table/Abstract.php(875): Zend_Db_Table_Abstract->_setupMetadata()
#3 /var/www/web4558/html/shopware/engine/Library/Zend/Db/Table/Abstract.php(983): Zend_Db_Table_Abstract->_setupPrimaryKey()
#4 /var/www/web4558/html/shopware/engine/Library/Zend/Db/Table/Select.php(100): Zend_Db_Table_Abstract->info()
#5 /var/www/web4558/html/shopware/engine/Library/Zend/Db/Table/Select.php(78): Zend_Db_Table_Select->setTable(Object(Enlight_Components_Table))
#6 /var/www/web4558/html/shopware/engine/Library/Zend/Db/Table/Abstract.php(1019): Zend_Db_Table_Select->__construct(Object(Enlight_Components_Table))
#7 /var/www/web4558/html/shopware/engine/Library/Enlight/Config/Adapter/DbTable.php(196): Zend_Db_Table_Abstract->select()
#8 /var/www/web4558/html/shopware/engine/Library/Enlight/Config/Adapter/DbTable.php(178): Enlight_Config_Adapter_DbTable->readSection(‚themes/bare/bac…‘, ‚1:1‘)
#9 /var/www/web4558/html/shopware/engine/Library/Enlight/Config.php(464): Enlight_Config_Adapter_DbTable->read(Object(Enlight_Components_Snippet_Namespace))
#10 /var/www/web4558/html/shopware/engine/Library/Enlight/Components/Snippet/Namespace.php(53): Enlight_Config->read()
#11 /var/www/web4558/html/shopware/engine/Shopware/Components/Snippet/Manager.php(130): Enlight_Components_Snippet_Namespace->__construct(Array)
#12 /var/www/web4558/html/shopware/themes/Frontend/Bare/Theme.php(174): Shopware_Components_Snippet_Manager->getNamespace(‚themes/bare/bac…‘)
#13 /var/www/web4558/html/shopware/themes/Frontend/Bare/Theme.php(140): Shopware\Themes\Bare\Theme->getLabelAttribute(‚apple_touch_ico…‘)
#14 /var/www/web4558/html/shopware/engine/Shopware/Components/Theme/Configurator.php(452): Shopware\Themes\Bare\Theme->createConfig(Object(Shopware\Components\Form\Container\TabContainer))
#15 /var/www/web4558/html/shopware/engine/Shopware/Components/Theme/Configurator.php(113): Shopware\Components\Theme\Configurator->injectConfig(Object(Shopware\Themes\Responsive\Theme), Object(Shopware\Components\Form\Container\TabContainer))
#16 /var/www/web4558/html/shopware/engine/Shopware/Components/Theme/Installer.php(154): Shopware\Components\Theme\Configurator->synchronize(Object(Shopware\Themes\Responsive\Theme))
#17 /var/www/web4558/html/shopware/engine/Shopware/Components/Theme/Installer.php(116): Shopware\Components\Theme\Installer->synchronizeThemes()
#18 /var/www/web4558/html/shopware/recovery/install/src/Service/ThemeService.php(61): Shopware\Components\Theme\Installer->synchronize()
#19 /var/www/web4558/html/shopware/recovery/install/src/app.php(438): Shopware\Recovery\Install\Service\ThemeService->activateResponsiveTheme()
#20 [internal function]: {closure}()
#21 /var/www/web4558/html/shopware/recovery/common/vendor/slim/slim/Slim/Route.php(462): call_user_func_array(Object(Closure), Array)
#22 /var/www/web4558/html/shopware/recovery/common/vendor/slim/slim/Slim/Slim.php(1326): Slim\Route->dispatch()
#23 /var/www/web4558/html/shopware/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()
#24 /var/www/web4558/html/shopware/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()
#25 /var/www/web4558/html/shopware/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()
#26 /var/www/web4558/html/shopware/recovery/common/vendor/slim/slim/Slim/Slim.php(1271): Slim\Middleware\PrettyExceptions->call()
#27 /var/www/web4558/html/shopware/recovery/install/index.php(74): Slim\Slim->run()
#28 {main}
Kann mir jemand sagen was diese bedeutet? Fehlen hier Schreibrechte?
Danke schon mal
