Hallo zusammen, ich bekomme beim letzten Schritt der Installation folgende Fehlermeldung Slim Application Error The application could not run because of the following error: Details Type: RuntimeException Message: Identifier DB not initialized yet File: /www/htdocs/w00da049/recovery/install/src/ContainerProvider.php Line: 160 Trace #0 /www/htdocs/w00da049/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(112): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install{closure}(Object(Pimple\Container)) #1 /www/htdocs/w00da049/recovery/install/src/ContainerProvider.php(143): Pimple\Container->offsetGet(‘db’) #2 /www/htdocs/w00da049/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(112): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install{closure}(Object(Pimple\Container)) #3 /www/htdocs/w00da049/recovery/install/src/app.php(436): Pimple\Container->offsetGet(‘theme.service’) #4 [internal function]: {closure}() #5 /www/htdocs/w00da049/recovery/common/vendor/slim/slim/Slim/Route.php(462): call_user_func_array(Object(Closure), Array) #6 /www/htdocs/w00da049/recovery/common/vendor/slim/slim/Slim/Slim.php(1326): Slim\Route->dispatch() #7 /www/htdocs/w00da049/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call() #8 /www/htdocs/w00da049/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call() #9 /www/htdocs/w00da049/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call() #10 /www/htdocs/w00da049/recovery/common/vendor/slim/slim/Slim/Slim.php(1271): Slim\Middleware\PrettyExceptions->call() #11 /www/htdocs/w00da049/recovery/install/index.php(74): Slim\Slim->run() #12 {main} Vor der Installation wird mir der Punkt memory_limit mit Erforderlich 256 und Ihr System 128 bemängelt. In der htaccess steht aber bereits php_value memory_limit 256M. Kann mir jemand sagen wie ich den Fehler wieder wegbekomme?
[quote=“ga-bwler”] Vor der Installation wird mir der Punkt memory_limit mit Erforderlich 256 und Ihr System 128 bemängelt. In der htaccess steht aber bereits php_value memory_limit 256M.[/quote] Je nach Serverkonfiguration wird die .htaccess beachtet oder eben auch nicht. Wenn Du die aktuellen PHP-Einstellungen auslesen möchtest, lege Dir folgendes Skript auf den Server und rufe es per Browser auf. Wenn Du dann wirklich nur 128MB PHP-Memory-Limit hast, solltest Du es mindestens auf 256MB erhöhen. <?php phpinfo();
