Fehlermeldung nach Installation
Hoster: alfahosting
PHP 7.2
Slim Application Error
Type:  RuntimeException
Message:  Identifier DB not initialized yet
File:  /var/www/web1065/html/shop4/recovery/install/src/ContainerProvider.php
Line:  155
Trace
#0 /var/www/web1065/html/shop4/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(118): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install{closure}(Object(Pimple\Container))
#1 /var/www/web1065/html/shop4/recovery/install/src/ContainerProvider.php(138): Pimple\Container->offsetGet(‘db’)
#2 /var/www/web1065/html/shop4/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(118): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install{closure}(Object(Pimple\Container))
#3 /var/www/web1065/html/shop4/recovery/install/src/app.php(496): Pimple\Container->offsetGet(‘theme.service’)
#4 [internal function]: {closure}()
#5 /var/www/web1065/html/shop4/recovery/common/vendor/slim/slim/Slim/Route.php(468): call_user_func_array(Object(Closure), Array)
#6 /var/www/web1065/html/shop4/recovery/common/vendor/slim/slim/Slim/Slim.php(1355): Slim\Route->dispatch()
#7 /var/www/web1065/html/shop4/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()
#8 /var/www/web1065/html/shop4/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()
#9 /var/www/web1065/html/shop4/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()
#10 /var/www/web1065/html/shop4/recovery/common/vendor/slim/slim/Slim/Slim.php(1300): Slim\Middleware\PrettyExceptions->call()
#11 /var/www/web1065/html/shop4/recovery/install/index.php(75): Slim\Slim->run()
#12 {main}
Hat jemand eine idee?
danke erstmal
  memory kann ich nur auf 384 MB einstellen Execution time ist auf 60 Sek
Die Installation ist auch durchgelaufen nach Fertigstellung und aufruf von
“http://shopware.basteln4u.de/recovery/install/index.php/finalize/”
kam diese Fehlermeldung…
Habe erstmal wieder auf php5.6  umgestellt, da der originalshop nicht mehr unter php7.2 zu sehen ist.
Bitteschön,
Beschäftige dich mal mit den absoluten Mindestvorraussetzungen - absolutes Minimum !:
Ich halte z.B. beim Memory Limit 1 GB fürs Minimum, das nutzt aber nichts wenn die Server überbucht sind, oder auch sonst nicht ordentlich konfiguriert sind, bzw. für derartige Shopsoftware gar nicht eingerichtet.
https://stackoverflow.com/questions/45637033/shopware-installation-error-identifier-db-not-initialized-yet
