Hallo zusammen, es handelt sich bei mir um eine :shopware: - Neuinstallation. Systemvorraussetzungen sind alle erfüllt, allerdings bekomme ich nach dem letzten Schritt der :shopware: - Installation folgende Fehlermeldung: [quote] Slim Application Error The application could not run because of the following error: Details Type: ErrorException Code: 1024 Message: Failed saving metadata to metadataCache File: /var/www/a/html/engine/Library/Zend/Db/Table/Abstract.php Line: 839 Trace #0 [internal function]: Slim\Slim::handleErrors(1024, ‚Failed saving m…‘, ‚/var/www/a/html…‘, 839, Array) #1 /var/www/a/html/engine/Library/Zend/Db/Table/Abstract.php(839): trigger_error(‚Failed saving m…‘, 1024) #2 /var/www/a/html/engine/Library/Zend/Db/Table/Abstract.php(875): Zend_Db_Table_Abstract->_setupMetadata() #3 /var/www/a/html/engine/Library/Zend/Db/Table/Abstract.php(983): Zend_Db_Table_Abstract->_setupPrimaryKey() #4 /var/www/a/html/engine/Library/Zend/Db/Table/Select.php(100): Zend_Db_Table_Abstract->info() #5 /var/www/a/html/engine/Library/Zend/Db/Table/Select.php(78): Zend_Db_Table_Select->setTable(Object(Enlight_Components_Table)) #6 /var/www/a/html/engine/Library/Zend/Db/Table/Abstract.php(1019): Zend_Db_Table_Select->__construct(Object(Enlight_Components_Table)) #7 /var/www/a/html/engine/Library/Enlight/Config/Adapter/DbTable.php(196): Zend_Db_Table_Abstract->select() #8 /var/www/a/html/engine/Library/Enlight/Config/Adapter/DbTable.php(178): Enlight_Config_Adapter_DbTable->readSection(‚themes/bare/bac…‘, ‚1:1‘) #9 /var/www/a/html/engine/Library/Enlight/Config.php(464): Enlight_Config_Adapter_DbTable->read(Object(Enlight_Components_Snippet_Namespace)) #10 /var/www/a/html/engine/Library/Enlight/Components/Snippet/Namespace.php(53): Enlight_Config->read() #11 /var/www/a/html/engine/Shopware/Components/Snippet/Manager.php(122): Enlight_Components_Snippet_Namespace->__construct(Array) #12 /var/www/a/html/themes/Frontend/Bare/Theme.php(169): Shopware_Components_Snippet_Manager->getNamespace(‚themes/bare/bac…‘) #13 /var/www/a/html/themes/Frontend/Bare/Theme.php(135): Shopware\Themes\Bare\Theme->getLabelAttribute(‚apple_touch_ico…‘) #14 /var/www/a/html/engine/Shopware/Components/Theme/Configurator.php(121): Shopware\Themes\Bare\Theme->createConfig(Object(Shopware\Components\Form\Container\TabContainer)) #15 /var/www/a/html/engine/Shopware/Components/Theme/Installer.php(156): Shopware\Components\Theme\Configurator->synchronize(Object(Shopware\Themes\Bare\Theme)) #16 /var/www/a/html/engine/Shopware/Components/Theme/Installer.php(117): Shopware\Components\Theme\Installer->synchronizeThemes() #17 /var/www/a/html/recovery/install/src/Service/ThemeService.php(61): Shopware\Components\Theme\Installer->synchronize() #18 /var/www/a/html/recovery/install/src/app.php(437): Shopware\Recovery\Install\Service\ThemeService->activateResponsiveTheme() #19 [internal function]: {closure}() #20 /var/www/a/html/recovery/common/vendor/slim/slim/Slim/Route.php(462): call_user_func_array(Object(Closure), Array) #21 /var/www/a/html/recovery/common/vendor/slim/slim/Slim/Slim.php(1326): Slim\Route->dispatch() #22 /var/www/a/html/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call() #23 /var/www/a/html/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call() #24 /var/www/a/html/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call() #25 /var/www/a/html/recovery/common/vendor/slim/slim/Slim/Slim.php(1271): Slim\Middleware\PrettyExceptions->call() #26 /var/www/a/html/recovery/install/index.php(74): Slim\Slim->run() #27 {main} [/quote] Ich habe Shopware manuell entpackt und dann via FTP hochgeladen. Wegen dem Fehler nochmal alles gelöscht und als .zip rauf geladen, via PHP-Script entpackt und wieder kam der Fehler nach der Installation… Ich hoffe auf Hilfe, da ich :shopware: schnellstens einrichten will, damit der Shop endlich live gehen kann. Ich bin schon seit ein paar Tagen damit beschäftigt
Danke für die Hilfe! Gruß Jan
