Liebes Shopware Forum,
ich stehe hier vor einem Problem! Der Cronjob lässt sich nicht mehr ausführen und es kommt zu folgender Fehlermeldung
Fatal error: Uncaught exception 'UnexpectedValueException' with message 'The stream or file "/var/www/vhosts/XXX/httpdocs/var/log/core_production-2016-04-15.log" could not be opened: failed to open stream: Permission denied' in /var/www/vhosts/XXX/httpdocs/vendor/monolog/monolog/src/Monolog/Handler/StreamHandler.php:84 Stack trace: #0 /var/www/vhosts/XXX/httpdocs/vendor/monolog/monolog/src/Monolog/Handler/RotatingFileHandler.php(88): Monolog\Handler\StreamHandler->write(Array) #1 /var/www/vhosts/XXX/httpdocs/vendor/monolog/monolog/src/Monolog/Handler/AbstractProcessingHandler.php(37): Monolog\Handler\RotatingFileHandler->write(Array) #2 /var/www/vhosts/XXX/httpdocs/vendor/monolog/monolog/src/Monolog/Handler/AbstractHandler.php(58): Monolog\Handler\AbstractProcessingHandler->handle(Array) #3 /var/www/vhosts/XXX/httpdocs/vendor/monolog/monolog/src/Monolog/Handler/FingersCrossedHandler.php(105): Monolog\Handler\Abstrac in /var/www/vhosts/XXX/httpdocs/vendor/monolog/monolog/src/Monolog/Handler/StreamHandler.php on line 84
503 Service Unavailable
Kann mir bitte jemand helfen, das Problem zu lösen?
Vielen lieben Dank!
Alexander
Fatal error: Uncaught exception ‚UnexpectedValueException‘ with message ‚The stream or file „/var/www/vhosts/XXX/httpdocs/var/log/core_production-2016-04-15.log“ could not be opened: failed to open stream: Permission denied‘ in /var/www/vhosts/XXX/httpdocs/vendor/monolog/monolog/src/Monolog/Handler/StreamHandler.php:84 Stack trace: #0 /var/www/vhosts/XXX/httpdocs/vendor/monolog/monolog/src/Monolog/Handler/RotatingFileHandler.php(88): Monolog\Handler\StreamHandler->write(Array) #1 /var/www/vhosts/XXX/httpdocs/vendor/monolog/monolog/src/Monolog/Handler/AbstractProcessingHandler.php(37): Monolog\Handler\RotatingFileHandler->write(Array) #2 /var/www/vhosts/XXX/httpdocs/vendor/monolog/monolog/src/Monolog/Handler/AbstractHandler.php(58): Monolog\Handler\AbstractProcessingHandler->handle(Array) #3 /var/www/vhosts/XXX/httpdocs/vendor/monolog/monolog/src/Monolog/Handler/FingersCrossedHandler.php(105): Monolog\Handler\Abstrac in /var/www/vhosts/XXX/httpdocs/vendor/monolog/monolog/src/Monolog/Handler/StreamHandler.php on line 84
Vielen lieben Dank!
Alexander
ansich steht es doch aber in der Fehlermeldung schon drin:
Der Cronjob schlägt fehl, weil er keine Log-Datei erzeugen kann, da ihm die Schreibrechte in dem Verzeichnis fehlen (Permission denied).
Beste Grüße
Sebastian
Vielen Dank, das Problem konnte ich beheben! Merci, Tip top!
