Fehlermeldung beim ausführen des Cronjobs
Hallo Ich bekomme folgende Fehlermeldung beim ausführen des Cronjobs
Shopware version 5.2.14 - /production
Usage:
  command [options] [arguments]
Available commands:
  help Displays help for a command
  list Lists commands
 db
  db:backup Create database backup.
 dbal
  dbal:import Import SQL file(s) directly to Database.
  dbal:run-sql Executes arbitrary SQL directly from the command
 synchronized.
  sw:es:backlog:sync Synchronize events from the backlog to the live index.
  sw:es:index:cleanup Remove unused Elasticsearch indices.
  sw:es:index:populate Reindex all shops into a new index and switch the live-system alias after the index process.
  sw:es:switch:alias Allows to switch live-system aliases.
  sw:firstrunwizard:disable Disable the first run wizard.
  sw:firstrunwizard:enable Enable the first run wizard.
  sw:generate:attributes Generates attribute models.
  sw:importexport:export Export data to files.
  sw:importexport:import Import data from files.
  sw:importexport:profiles Show all profiles.
  sw:media:cleanup Collect unused media and move them to trash.
  sw:media:migrate Migrate images to new structure
  sw:migrate:article:attribute:translations Migrates article attribute translations from Shopware 5.1 to Shopware 5.2
  sw:migrations:migrate
  sw:plugin:activate Activates a plugin.
  sw:plugin:config:list Lists plugin configuration.
  sw:plugin:config:set Sets plugin configuration.
  sw:plugin:deactivate Deactivates a plugin.
  sw:plugin:delete Deletes a plugin.
  sw:plugin:install Installs a plugin.
  sw:plugin:list Lists plugins.
  sw:plugin:refresh Refreshes plugin list.
  sw:plugin:reinstall Reinstalls the provided plugin
  sw:plugin:uninstall Uninstalls a plugin.
  sw:plugin:update Updates a plugin.
  sw:product:feeds:refresh Refreshes product feed cache files.
  sw:rebuild:category:tree Rebuild the category tree
  sw:rebuild:seo:index Rebuild the SEO index
  sw:refresh:search:index Refreshes and regenerates the search index
  sw:settings:label:find:missing Dump missing settings labels from the database into php arrays files
  sw:snippets:find:missing Find missing snippets in the database and dumps them into .ini files
  sw:snippets:remove Remove snippets from the database for a specific folder
  sw:snippets:to:db Load snippets from .ini files into database
  sw:snippets:to:ini Dump snippets from the database into .ini files
  sw:snippets:to:sql Load snippets from .ini files into sql file
  sw:snippets:validate Validates .ini files containing snippets
  sw:store:download Downloads a plugin from the community store
  sw:store:list List licensed plugins.
  sw:store:list:domains List connected domains.
  sw:store:list:integrated List all integrated plugins.
  sw:store:list:updates Lists updates for installed plugins.
  sw:theme:cache:generate Generates theme caches.
  sw:theme:create Creates a theme.
  sw:theme:dump:configuration Dumps the theme configuration into json files
  sw:theme:initialize Initializes themes. Enables responsive theme for the default shop.
  sw:thumbnail:cleanup Deletes thumbnails for images whose original file has been deleted.
  sw:thumbnail:generate Generates a new Thumbnail.
  sw:warm:http:cache Warm up http cache
 swaglicense
  swaglicense:import Import licenses from file.
  swaglicense:list Lists available licenses.
 viison
  viison:dhl:accountinfo Get DHL GK account info.
Content-type: text/html; charset=UTF-8
Warning: Invalid argument supplied for foreach() in /html/shopware/vendor/symfony/console/Input/ArgvInput.php on line 285
Warning: Invalid argument supplied for foreach() in /html/shopware/vendor/symfony/console/Input/ArgvInput.php on line 262
Manuell läuft der Cronjob ohne Probleme.  Hat evtl. jemand ne Idee wo das Problem liegt.
Vielen Dank im Voraus.
Gruß
Mirko
Kannst du die Befehle denn ausführen?
Das geht aus deiner Meldung da überhaupt nicht hervor. Da sehe ich erstma nur ein PHP-Warning und keinen Error/Fehler.
Hallo Moritz,
danke für deine schnelle Reaktion. Ich kann den Chronjob manuell starten über https://www.meinshop.de.com/backend/cron  dann wird auch alles ausgeführt. so wie es soll.
Wenn es automatisch läuft dann bin ich der Meinung es funktioniert nicht.
Wenn ich mir die Chronjobs bei den Grundeinstellungen ansehe wird beim automatischen ausführen das Datum des letzten Ausfpührens  nicht geändert, das klappt aber bei der manuellen Ausführung.
Gibt es eine Möglichkeit das man das noch anders prüfen kann?
das Problem besteht immer noch. Habe jetzt festgestellt das der Fehler anscheinend seit dem Update von Version
5.2.3 auf 5.2.14 besteht auch nach dem Update auf 5.2.16 besteht das Problem weiter.  Wurde beim Update
seitens Shopware etwas zum Thema cronjob verändert?
Hat evtl. Jemand ne Idee?
Gruß
Mirko
