Liebes Forum
Gestern wollte jemand bei mir bestellen, hat sich auch schon angemeldet, aber bei der Bestellung kam der folgende Fehler:
exception ‚Shopware\Components\Api\Exception\NotFoundException‘ with message ‚Order by id 1569 not found‘ in /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Components/Api/Resource/Order.php:122
Stack trace:
#0 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Controllers/Api/Orders.php(68): Shopware\Components\Api\Resource\Order->getOne(‚1569‘)
#1 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Controller/Action.php(159): Shopware_Controllers_Api_Orders->getAction()
#2 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch(‚getAction‘)
#3 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#4 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Kernel.php(182): Enlight_Controller_Front->dispatch()
#5 /var/www/vhosts/meinshop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(491): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#6 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(266): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#7 /var/www/vhosts/meinshop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(448): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#8 /var/www/vhosts/meinshop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(344): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true)
#9 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(187): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#10 /var/www/vhosts/meinshop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(210): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#11 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(114): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#12 /var/www/vhosts/meinshop.de/httpdocs/shopware.php(117): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#13 {main}
2017-08-09T16:19:53.172336+0200
core
„uri“: „/api/orders/1569/“,
„method“: „GET“,
„query“: {
„module“: „api“,
„controller“: „orders“,
„action“: „1569“
„post“:
No shop data available
No session data available
Die Bestellnummer scheint nicht gefunden zu werden. Woran könnte das liegen ?
Er scheint es mehrmals versucht zu haben, denn die Fehlermeldung kam 4 Mal.
Liebe Grüße
Kerstin ![]()
