Fehlermeldung bei "Artikel - Übersicht"
Hallo sehr geehrte Community,
ich stehe absolut vor dem rätzel, wie diese Fehlermeldung behoben werden kann…
Could not find nor create ‚/var/www/vhosts/gametech-hosting.de/httpdocs/files/backup/‘ in Shopware/Components/MultiEdit/Resource/Product/Backup.php on line 112
Stack trace:
 #0 Shopware/Components/MultiEdit/Resource/Product/Backup.php(87): Shopware\Components\MultiEdit\Resource\Product\Backup-\>setupBackupDir() #1 var/cache/production\_201604081130/proxies/ShopwareProductionProjectContainer.php(553): Shopware\Components\MultiEdit\Resource\Product\Backup-\>\_\_construct(Object(Shopware\Components\MultiEdit\Resource\Product\DqlHelper), Object(Shopware\_Components\_Config)) #2 vendor/symfony/dependency-injection/Container.php(327): ShopwareProductionProjectContainer-\>getMultiEdit\_Product\_BackupService() #3 Shopware/Components/DependencyInjection/Container.php(253): Symfony\Component\DependencyInjection\Container-\>get('multi\_edit.prod...') #4 Shopware/Components/DependencyInjection/Container.php(188): Shopware\Components\DependencyInjection\Container-\>load('multi\_edit.prod...') #5 var/cache/production\_201604081130/proxies/ShopwareProductionProjectContainer.php(573): Shopware\Components\DependencyInjection\Container-\>get('multi\_edit.prod...') #6 vendor/symfony/dependency-injection/Container.php(327): ShopwareProductionProjectContainer-\>getMultiEdit\_Product\_QueueService() #7 Shopware/Components/DependencyInjection/Container.php(253): Symfony\Component\DependencyInjection\Container-\>get('multi\_edit.prod...') #8 Shopware/Components/DependencyInjection/Container.php(188): Shopware\Components\DependencyInjection\Container-\>load('multi\_edit.prod...') #9 var/cache/production\_201604081130/proxies/ShopwareProductionProjectContainer.php(557): Shopware\Components\DependencyInjection\Container-\>get('multi\_edit.prod...') #10 vendor/symfony/dependency-injection/Container.php(327): ShopwareProductionProjectContainer-\>getMultiEdit\_Product\_BatchProcessService() #11 Shopware/Components/DependencyInjection/Container.php(253): Symfony\Component\DependencyInjection\Container-\>get('multi\_edit.prod...') #12 Shopware/Components/DependencyInjection/Container.php(188): Shopware\Components\DependencyInjection\Container-\>load('multi\_edit.prod...') #13 var/cache/production\_201604081130/proxies/ShopwareProductionProjectContainer.php(549): Shopware\Components\DependencyInjection\Container-\>get('multi\_edit.prod...') #14 vendor/symfony/dependency-injection/Container.php(327): ShopwareProductionProjectContainer-\>getMultiEdit\_ProductService() #15 Shopware/Components/DependencyInjection/Container.php(253): Symfony\Component\DependencyInjection\Container-\>get('multi\_edit.prod...') #16 Shopware/Components/DependencyInjection/Container.php(188): Shopware\Components\DependencyInjection\Container-\>load('multi\_edit.prod...') #17 Shopware/Controllers/Backend/ArticleList.php(80): Shopware\Components\DependencyInjection\Container-\>get('multi\_edit.prod...') #18 Enlight/Controller/Action.php(158): Shopware\_Controllers\_Backend\_ArticleList-\>columnConfigAction() #19 Enlight/Controller/Dispatcher/Default.php(523): Enlight\_Controller\_Action-\>dispatch('columnConfigAct...') #20 Enlight/Controller/Front.php(226): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #21 Shopware/Kernel.php(153): Enlight\_Controller\_Front-\>dispatch() #22 vendor/symfony/http-kernel/HttpCache/HttpCache.php(492): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #23 Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #24 vendor/symfony/http-kernel/HttpCache/HttpCache.php(263): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #25 Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #26 shopware.php(101): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #27 {main} Habe schon alles ausprobiert, aber es wieder gerade zu biegen funktioniert absolut nicht. Als nächstes Problem, ich wollte ein Artikel bearbeiten und dabei bekam ich die oben genannte Fehlermeldung. Ich kann keine Artikel mehr bearbeiten. Weiß jemand vielleicht wie ich es wieder gerade biege damit ich die Artikel bearbeiten kann? Mfg
schau mal hier: http://forum.shopware.com/discussion/comment/158377/#Comment_158377
Das Problem steht ja da im Detail in der Meldung, was schief läuft :wink:
Sebastian
Dieser Ordner “Backup” existiert garnicht…
Mfg
Das war der erste Teil der Meldung.
Jetzt musst du noch das „oder“ (bzw. „weder“) überprüfen.
Hat alles wieder funktioniert, danke für die Hilfe
