Fehler nach dem Update.
Hallo Community,
ich betreffe ein Fehler sobald ich auf Irgendwelche Kategorie clicke.
Die nachfolgenden Hinweise sollten dir weiterhelfen.
Syntax Error 49" on line 1 "{literal}{"ecommerce":{"currencyCode":"{/literal}{0|currency:USE_SHORTNAME:LEFT|substr:0:3}{literal}","impressions":[{/literal}{foreach from=$sArticles item=sArticle name=loop}{literal}{"name":"{/literal}{$sArticle.articleName|escape}{literal}","id":"{/literal}{$sArticle.ordernumber|escape}{literal}","price":"{/literal}{$sArticle.price_numeric}{literal}","brand":"{/literal}{$sArticle.supplierName|escape}{literal}","category":"{/literal}{$sCategoryContent.name|escape}{literal}","list":"{/literal}Category{literal}","position":"{/literal}{($pageIndex|default:1 - 1) * {config name=articlesperpage} + {$smarty.foreach.loop.iteration}}{literal}"}{/literal}{if !$smarty.foreach.loop.last},{/if}{/foreach}{literal}]},"google_tag_params":{"ecomm_pagetype":"{/literal}category{literal}","ecomm_prodid":"{/literal}[{foreach $sArticles as $sArticle}\"{$sArticle.ordernumber|escape}\"{if !$sArticle@last},{/if}{/foreach}]{literal}","ecomm_category":"{/literal}{$sCategoryContent.name|escape}{literal}"}}{/literal}" modifier 'substr' not allowed by security setting in engine/Shopware/Components/StringCompiler.php on line 178
Stack trace:
#0 engine/Shopware/Components/StringCompiler.php(148): Shopware_Components_StringCompiler->compileSmartyString('{literal}{"ecom...', Array)
#1 custom/plugins/WbmTagManager/Subscriber/Frontend/PostDispatch.php(137): Shopware_Components_StringCompiler->compileString('{literal}{"ecom...')
#2 custom/plugins/WbmTagManager/Subscriber/Frontend/PostDispatch.php(118): WbmTagManager\Subscriber\Frontend\PostDispatch->compileString('{literal}{"ecom...')
#3 custom/plugins/WbmTagManager/Subscriber/Frontend/PostDispatch.php(84): WbmTagManager\Subscriber\Frontend\PostDispatch->fillValues('{literal}{"ecom...')
#4 engine/Library/Enlight/Event/Handler/Default.php(91): WbmTagManager\Subscriber\Frontend\PostDispatch->onPostDispatch(Object(Enlight_Controller_ActionEventArgs))
#5 engine/Library/Enlight/Event/EventManager.php(214): Enlight_Event_Handler_Default->execute(Object(Enlight_Controller_ActionEventArgs))
#6 engine/Library/Enlight/Controller/Action.php(196): Enlight_Event_EventManager->notify('Enlight_Control...', Object(Enlight_Controller_ActionEventArgs))
#7 engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch('indexAction')
#8 engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#9 engine/Shopware/Kernel.php(182): Enlight_Controller_Front->dispatch()
#10 vendor/symfony/http-kernel/HttpCache/HttpCache.php(491): Shopware\Kernel->handle(Object(Enlight_Controller_Request_RequestHttp), 1, true)
#11 engine/Shopware/Components/HttpCache/AppCache.php(266): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#12 vendor/symfony/http-kernel/HttpCache/HttpCache.php(448): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#13 vendor/symfony/http-kernel/HttpCache/HttpCache.php(344): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true)
#14 engine/Shopware/Components/HttpCache/AppCache.php(187): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#15 vendor/symfony/http-kernel/HttpCache/HttpCache.php(210): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#16 engine/Shopware/Components/HttpCache/AppCache.php(114): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#17 shopware.php(117): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#18 {main}
Bitte um Hilfe.
WbmTagManager ist die Ursache - deaktivieren!
Einfach den WbmTagManager deaktivieren und Cache leeren
Da wart ihr sehr schnell, ich wollte gerade Problem und Lösung melden Thumb-Up
Wua, ihr wart echt Schnell! Danke :slight_smile:
